Technika LCD26-209
  • diif
    • Feb 2014
    • 6978
    • England
    Technika LCD26-209
    Another of Vestel's finest that i've been given. I can almost hear the groaning.
    Loads of leaking and bloated caps in the 17PW26-3 PSU which i replaced.
    I replaced all of the samxon and tested the four remaining HEC caps with my ECR meter and they were fine.
    I powered on the TV and was greeted by a blue screen with a compressed coloured band at the top. After about 5 seconds the line scans down, appears at the top the does it again.
    https://www.dropbox.com/s/qrznmb8c9t...53714.mp4?dl=0
    As it warms up the line disappears and slowly the refresh rate speeds up to a perfect picture.
    https://www.dropbox.com/s/gr4ntaoenz...11217.mp4?dl=0
    I appologise for the dropbox links, i don't have a youtube account.
    I've been over with a hairdryer and warmed each bit up (maybe i missed something) but it doesn't seem to make any difference.
    Any ideas what i'm missing ?
    Thanks.
  • michael dranfield
    • Jan 2016
    • 232
    • England
    Re: Technika LCD26-209
    looks like a duff screen to me .
    • diif
      • Feb 2014
      • 6978
      • England
      I thought so too initially , but give it 10 minutes to warm up and the picture is perfect.
      • michael dranfield
        • Jan 2016
        • 232
        • England
        There are chips mounted on the side of the screen and along the top , try heating and cooling the one that corresponds to where you have the black line ..
        • diif
          • Feb 2014
          • 6978
          • England
          Cheers Michael, the black line seemed to scan down the screen refreshing the screen as i moved. I'll have a look for those chips.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Reseat the Lvd cable if it uses that flat flex type one
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Ive had quite two of them 17MB35's with that flat ribbon the pins on it becomes broken and causes glitches like this. I have a youtube video on it being uploaded soon if not that Lcd is dud.
              • diif
                • Feb 2014
                • 6978
                • England
                It was the last 4 HEC capacitors. They all have a low esr and are within spec, but i replaced them and the image issue has gone away.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Got images of the positions of the caps mate ?
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    I didn't take any photos but i've circled on a borrowed image. It was a 17PW26-3 and it is the three 1000uf 35v and one 2200uf 6.3v. I'm blaming you Reecey lol, i remember from one of your videos where you say HEC are ok
                    They measure
                    917.6uf 0.06ohms
                    935.7uf 0.06ohms
                    922.0uf 0.06ohms
                    2135uf 0.04ohms
                    Maybe it wasn't these and it was the tab bonds that got disturbed but it seemed to be a heat issue that took about 10 minutes each time to occur from cold.
                      • 31015
                      the cheap - as in under $xxx testers cant check ripple current.
                      that's an important figure in psu caps.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Cheers stj. That makes sense.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Hmm I dont think them HEC's caused the issue they are fine. Ohh well if it works now good haha
