New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
If anyone can provide:
A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
spero che qualcuno può averlo per riprogrammare eprom. grazie
Post in English !!!
I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
- Toshiba 65UL2163DG
- Vestel 17MB180E mainboard
- Panel VES650QNTX-N2-N42
- Version V1.28.100.0 if available
If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
I suspect corrupt firmware but I haven't been able to find anything for this TV.
TV model: Finlux 65-FUC-8060
Mainboard: Vestel 17MB130S 23473048
Panel: VES650QNTS-2D-U11
At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
