Need Insignia NS-32D201NA14 Error Codes
    This insignia ns-32d201na14 LED T V uses the red power light in the front of the set to signal the error codes and it is flashing two times. Can someone please post the error codes or let me know what the two blinks indicates?
    Thanks.
    Re: Need Insignia NS-32D201NA14 Error Codes
    A shorted diode next to the 12 volt fuse on the t-con board was causing the two blink error code.
      Dude it's hilarious yours went out too at the exact same time as mine... Same exact TV.
      Can you take a pic? I have no idea what the T-Con board is... I replaced the master board and power board and had the same issue...
        Just do the search using the tv model number and follow by the word t-con and you will see lots of hit for the t-con board.
          I found the t-con board but as far as where the diode beside the 12v shorts is my question... Maybe just by eyeballing it, it will be obvious...
            Is that your T-CON board? Insignia tends to use more than one LCD panel supplier for the same model TV, same for other boards inside the same model.
            We need really good clear pictures of the board.
              Nope that's what I found looking up the model's tv t-con board on google... I had the TV apart... see 2 boards power and master then below is a board with 3 ribbon connections board on the bottom edge in the center of the tv... I have no idea lmao
                The t-con will be under the metal shield, it will bet at either at top edge center or bottom edge center of the LCD panel.
                How about providing the picture of the whole back side of the TV?
