Hisense 50H5G has sound no backlight
  • nwcs
    • Dec 2015
    • 311
    • usa
    I just got this one, customer was watching and the picture faded but they could still see the picture. Changed the channel and picture came back. Then later it went black. I can see the picture but no back light. I am suspecting a open led but I do not see the usual flash of back light when I turn it on. Checked the voltages to the led's 220V on red lead and 110V on white. XP805 on the power supply board is gnd, gnd, pwm is 5v, sw is 4v, 12, 12, stb is 4v, gnd then the last two are both 19v but should be 16v. Am I right in thinking it is a open led or should I be looking at something else?
    Re: Hisense 50H5G has sound no backlight
    More likely open circuit in the LED strings due to open LED or open connections between LED strips.
    You only has two wires to the LED strips inside the panel so the strips are connected in series to form one long LED string.
    • nwcs
      • Dec 2015
      • 311
      • usa
      Kind of what I thought. I have been replacing led strips like crazy in LG and toshiba tvs but they always seem to flash the few leds that do light up, and since they usually have more than two that makes sense. I will take the panel apart and take a look. I am not even sure if the led's are available for this TV.
        The LED strips/LEDs are connected in series like Christmas lights so one goes open circuit then the whole thing will not light up, but if the LED shorted out then the string will still light up.
        • nwcs
          • Dec 2015
          • 311
          • usa
          Removed the lcd panel and tested all of the led strips. Found two bad led's in one strip were open. I want to make sure but has anyone bypassed the led's by shorting around them?
            Not good idea to bypass, you can use 3.3V 1W Zener connected in reverse bias or use 5 1N4007 connected in series to simulate Vf of one LED.
            https://www.badcaps.net/forum/showthread.php?t=46403
            https://www.badcaps.net/forum/showthread.php?t=51251
            • nwcs
              • Dec 2015
              • 311
              • usa
              I will try that. I need to order the diodes first since I do not seem to have any. I just got back into TV repair after being out of it for 10 years. All of the TV repair shops in our county have closed for health or other reasons.
              • nwcs
                • Dec 2015
                • 311
                • usa
                Well it turns out I did have some 1n4728 zener's in the store soldered them in and now all of the led's work now. Thanks for all of the help BUDM.
                  Thanks for the follow-up, you should also turn down the Backlights level as low as you can to extend the life of the LEDs.
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    I do that on any tv that I replace the led's in. Thanks again for the help.
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • triplefour
                      by triplefour
                      09-13-2023, 10:43 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • DKWS89
                      Sony XBR 49x900E - Sound and backlight on but no picture
                      by DKWS89
                      Hey Guys,
                      So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                      All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                      12-14-2023, 04:30 PM
