Mosfet ?
  • colormebad
    colormebad
    • 114
    Mosfet ?
    Anyone know a sub part for this transistor ---> 16NF25
    Has a big ST stamped at the bottom.... thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Mosfet ?
    https://cdn.badcaps-static.com/pdfs/...46ca16067a.pdf
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Re: Mosfet ?
      Why not just get the right one...?
      Its not like its some oddball type by some weird far-eastern maker....
      ST micro well known popular American maker...
      TELEFIX
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: Mosfet ?
        I agree just because its failed does not mean its a bad series etc. Transistors tend to blow after they fatigue over time its normal.
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Re: Mosfet ?
          Aye-- Normal since the Effin' Greenies took Lead outta 'em!!
          NASA will not use Any 'RoHS' parts in anything they need to rely on for some years Medical and Military gear is also exempt from RoHS Directive--Gotta say summit--innit!...
          TELEFIX
            • 31190
            Re: Mosfet ?
            fuck lead, just use decent solder wih good flux in it like kristall505 or hs10
            bitching about RoHS is just an excuse to buy cheap crap on ebay instead of investing in decent solder
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              Re: Mosfet ?
              Err--
              You are Completely Missing the Point!!
              The MOSFETS/Parts Themselves have internal soldered parts like the Die or chip thats Soldered to the tab or substrate--Now by RoHS lead-free Crap!!
              Bitching about the quality of the solder used to replace the complete assembled TO220 or other package is gonna be like closing the stable After horse has Long Gone!!
              Its whats INSIDE the parts that matters!!
              BTW--
              I Will Not use lead-free solder at all, so dunno what the wise crack about using cheap solder off ebay was all about....
              TELEFIX
                • 31190
                Re: Mosfet ?
                the wisecrack about cheap solder was refering to chinese leaded 60/40 on ebay with no details about flux formulation etc.
                the chinese are offloading it because they have stricter RoHS rules than we do!
                component wires are bonded to the die, not soldered btw.
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  Re: Mosfet ?
                  And the Die--Often the Drain in MOSFETS is Soldered to the Tab or Substrate which forms the connection to outside world....
                  Two welded and One Soldered connection. Its Metal Fatigue due to expansion/contraction cycles that kills 'em. Google for RoHS and the NASA report, tells it all.
                  TELEFIX
                    • 31190
                    Re: Mosfet ?
                    i dont need to google anything,
                    i'v been watching the situation since it was just an idea and not a regulation.
                    it's all down to the flux, it was the development of new fluxes that held it back for so long.
                    that's why i tell people not to buy solder just based on the metals, but to pay attention to the flux formula - and if it's not detailed then dont buy it.
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Re: Mosfet ?
                      Nah--Nowt do do with flux, IMHO....
                      Its the alloys. Lead--Was there, For a Reason.....
                      It has been for Hundreds of years in various industries and used since the dawn of electronics till a few years ago, when the most damnable, ill-thought out, stupid, braindead, uninformed, Idiot, Interfereing, meddling Greenie A-Hole Numpties took it away, Curse their eyes!
                      Flux has little effect on the Metal-Fatigue the joints suffer from inside the die/substrate interface--THAT Fact is down to the metal Alloy Composition--as has been illustrated in the NASA reports you are reluctant to examine....
                      --Summit is either 'Tinned' correctly--Or Not--which is the purpose of the flux.
                      A poor alloy (Lead free crap) solder, unequal expansion hot/cold cycling and time does the rest.
                      IF it was as simple as flux formulation--which you allege has now been cured, then RoHS CRAP would be allowed in Medical and Military, and I doubt NASA would have Any problem in using such parts that are made in accordance with RoHS...
                      Nah--Keep yer lead-free rubbish, I'll use Proper Leaded Solder and Tried and tested Rosin based fluxes thanks!
                      --IF I had a choice--I would use all NON RoHS parts too, sadly this isn't possible anymore.
                      TELEFIX
                        • 31190
                        Re: Mosfet ?
                        it is.
                        there is no ban on leadfee solder being used in medical / defense equipment.
                        they are just exempt (so far) from being fined for using lead or cadmium.
                        unlike you or me - if we use lead while making something new to sell or for repairing something that was RoHS compliant we can get fined upto 50,000
                        and they DO enforce that!
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Re: Mosfet ?
                          it is.
                          Correct--The Military and Medical are Exempt. They Choose NOT to use RoHS due to the reliability concerns.....
                          (Due to the reliability issues--This has lead to MORE WEEE in the world to deal with--Rather Counter-Productive to what the Damnable Greenies wanted dont you think!)
                          BTW--What country are you in that goes to the trouble of checking your repaired work for RoHS Compliances?
                          --Europe is a Big place!
                          TELEFIX
                            • 31190
                            Re: Mosfet ?
                            u.k. right now,
                            and they do random checks on repair shops in London - because they would love to get some cash from people.
                            it's always about the money - like police pulling people over using a bullshit excuse just so they can check tread wear, rim damage etc.
                            • Alastair E
                              Chief Womble
                              • Mar 2013
                              • 1963
                              • U.K.
                              Re: Mosfet ?
                              Interesting....
                              Glad I'm in Welsh-Wales then!
                              Do you know anyone personally that has been prosecuted and ACTUALLY fined for using leaded solder to repair an item made post 2006, and NOT just rumor mongering in workshops on coffee breaks. (Lets face it--That happens a LOT)...?
                              The Maker can use up to 0.1% By Weight of finished Product of a RoHS applicable Chemical--Such as (In this example,) Lead.--And be Fully Compliant. This is quite plain in the RoHS Directive...
                              Otherwise, they wouldn't have been able to use CCFL tubes in TV sets, due to the Mercury,--another RoHS Chemical....
                              So--Do the rules say anything on how such analysis of said repaired item would confirm 0.1% by weight of the finished repaired item?
                              --Seeing only a couple of inches of 60/40, 0.5mm (used for average repair) would be well below 0.1% weight of any TV set! Such an amount of solder weighs less than a gram!
                              --How much did that plasma you just fixed weigh......
                              How are they gonna know --beyond reasonable doubt in a Court-- that you used that particular solder, and not some previous repairer--or even the maker....?
                              Only way to find quantity would be by destructive testing of that device and an elemental analysis done on the ash left to effectively estimate lead contents.....
                              --Doubt the owner of said repaired item would be too happy with That-
                              -IF it wasn't a trap item used by whoever polices the RoHS directive in your country!
                              Ive recently read through the RoHS Directive, didn't say much in the way of repairs--Perhaps you can quote the Chapter, Part, or Annex etc thats listed in, and where it mentions penalties for contraventions? Maybe the version I was reading is incomplete....
                              Only reference I found to fines was for 5,000 not 50,000 and that was for a Producer who obviously wasn't complying and not for a repairer.
                              --Maybe its because there are so few repairers left in comparison to 30 years ago.....
                              TELEFIX
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                Re: Mosfet ?
                                Out of curiosity, Ive emailed the NMRO. Here's what I said--
                                With regards to Repairs of Electronic Devices made After 2006, is it an offence to use a couple of inches of 60/40 0.5mm Lead-Tin Alloy (Traditional) Solder weighing less than a gram for the repair of an item of many Kg?
                                (Well within the 0.1% of the limit for lead in a Production environment)
                                This is for Repairs, and nothing at all connected to Production and placing on the market of a new item.
                                Thanks,
                                Al
                                TELEFIX
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Re: Mosfet ?
                                  This, I Absolutely agree with!
                                  There's Nothing done Anywhere in the world that Someone or some organisation doesn't benefit from financially.
                                  --There's Very little selflessness left in society its all What can you do for me, and how can I screw dosh outta you!
                                  A Narcissistic driven society, It'll eventually collapse in on itself, the cracks are plain to see already....
                                  Don't get me started on Motoring issues!!
                                  TELEFIX
                                  • Jane
                                    How do you test MOSFET in laptops ?
                                    by Jane
                                    I tried to use this method:
                                    Testing an N-channel MOSFET:
                                    Step 1: Discharge the Gate (turn off the MOSFET)
                                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                    Step 2: Charge the Gate (turn on the MOSFET)
                                    Now, place the red probe on the Gate (G) and the black probe on the
                                    09-27-2024, 03:31 AM
                                  • littlejohn
                                    mosfet or transistor ?
                                    by littlejohn
                                    I'm working on a LED circuit board and am testing a 8C 1A component, it has a wide ground tab on one side and 3 tabs on the other and the center tab is grounded also. the circuit board has it as a V2 component ,so is this a mosfet or transistor ?
                                    08-03-2025, 10:32 AM
                                  • Nooy
                                    VGA MOSfet permanently shorted and loss of MOSfet pad
                                    by Nooy
                                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                    02-14-2024, 02:26 AM
                                  • redbaron1007
                                    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                    by redbaron1007
                                    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                    09-09-2025, 11:10 AM
                                  • vikivng
                                    guys..i need help with this lcd display used on ebikes pls.
                                    by vikivng
                                    This is an lcd display used on ebikes.
                                    long story short, there was condensation inside the unit.
                                    I opened it and thoroughly cleaned the pcb with isopryl.
                                    The board had no visible corosion.
                                    It powered on fine and was tested for an hour or so.
                                    However when connected to the bike,,it did not power on at all.
                                    I took it home and reopened it to take a look. There are no shorts based on MY testing.
                                    However,,when I probe the transistor and the mosfet gate in diode mode or contuinity mode, (one probe on transistor collector and one probe on mosfet gate}the unit...
                                    09-16-2025, 12:56 PM
