LG Infinia 60PZ750 Sound and Not Picture
  • ElctroNYC
    • Sep 2013
    • 20
    • Usa
    Hello. I have a LG Infinia 60PZ750 . I change the Z-sustain board in my tv and it gives me sound but not picture. I disconnect the Y-sustain board and left the Z-sustain connected and it gave me sound but not picture then I disconnect the Z-sustain and connected back the Y-sus and again it gave me sound but not picture.
    I check both fuses in the boards and they seem to be ok unless i am checking them wrong.
    Could this be a y-buffer problem?
    please help
    Thanks in advance
    P.s the z-sustain in this picture was the one that got replaced.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG Infinia 60PZ750 Sound and Not Picture
    Does the screen appear to glow in a dark room ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Normally on these if the Sus boards or buffer are shot the Tv will not start.
      • ElctroNYC
        • Sep 2013
        • 20
        • Usa
        hmm didn't check that I will check that tomorrow. But at first sight I didn't see any glow.
        • ElctroNYC
          • Sep 2013
          • 20
          • Usa
          yeah with the old Z-sus the tv will turn on and turn off in less than 2 or 5 seconds. At least now the tv stays on.
          • ElctroNYC
            • Sep 2013
            • 20
            • Usa
            I checked and I didn't see any glow.
            • freakaftr8
              • Oct 2012
              • 3743
              Look at your Z sustain board on the bottom where the coils are is the board pretty darkened and are the coils making a bad solder connection to the bottom of the board cracked solder and very dull gray looking?
              You never know if somebody told you a bad board. Also are all your screws in the Y and Z board in and tight? these TVs do not like to run if you have any screws missing from either board
              • ljintexas
                LJinTexas
                • Jan 2015
                • 669
                can you tell me what the resolution was for this? I have one on the way in with this exact issue.
                TIA
                LJ
                • Nick's Tvs
                  • Jan 2014
                  • 621
                  If you didn't screw in all the screws on the board nice and tight after replacing it, you probably broke your new board. This is one of those boards where all screws needs to be in tight or else the new boards will go out instantly.
                  When these go out, they distinctly get an open fuse and like freakaftr8 suggested check the inductor solder joints. Those crack up pretty bad and your boards looks really dark next to them, so I really wouldn't be surprised if they are cracked.
                  • ljintexas
                    LJinTexas
                    • Jan 2015
                    • 669
                    I have it on the bench..I will attempt to fire it up..Previous owner reported sound and no pictures. Just found out I am road tripping next couple days..Yuck
                    • ljintexas
                      LJinTexas
                      • Jan 2015
                      • 669
                      Very nice looking set.
                      • ljintexas
                        LJinTexas
                        • Jan 2015
                        • 669
                        Just got back..will report findings shortly on initial fire up. Had to put my Mom in hospice care for her remaining days. Cancer is a terrible terrible disease.
                        At least she is resting comfortably.
                        • ljintexas
                          LJinTexas
                          • Jan 2015
                          • 669
                          Vs and Va are good. Fuse blown on z sustain. I do have audio and no video.
                          Going to pull Z sus and send it to Nick or PTS Electronics for repair.
                          • ljintexas
                            LJinTexas
                            • Jan 2015
                            • 669
                            Is this board repairable?
                            Looks kind of toasty but not too bad compared to some others I have seen that were definitely not repairable. Nick, I think this question is for you, buddy! if doable, it's coming your way. The stand-offs definitely need cleaning..they have what looks like carbon on them..Is alcohol and a q-tip acceptable or should I use tuner cleaner? A few of the screws were what I would call barely snug. Would it be a good idea to use some Loctite thread locker going back?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Hmm I think your coil has broken though the solder lol Yes you can use IPA and cleaning swabs to clean the soot off. Also resolder them with alot of freah solder to help prevent future failures. Also take the Ysus out and preform the same repair on it.
                              • ljintexas
                                LJinTexas
                                • Jan 2015
                                • 669
                                I will go and remove the Ysus now for inspection..thanks Reecey!
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  Here are pics of the solder joints for the coils and the IGBTs on the Ysus. should I reflow them anyway?\
                                  LJ
                                  • ljintexas
                                    LJinTexas
                                    • Jan 2015
                                    • 669
                                    Resoldered all coils, mosfets, igbts..main power caps. No discoloration anywhere on Ysus.
                                    • ljintexas
                                      LJinTexas
                                      • Jan 2015
                                      • 669
                                      Nick will have Zsus today for repair..no evident heat on Ysus. Resoldered for 30 min on Ysus as suggested by Reecey. Damn thats alot of components on heat sinks!!
                                      • Nick's Tvs
                                        • Jan 2014
                                        • 621
                                        You don't really need to get lock screws, the regular ones that come with the set are fine as long as you don't leave them loose. Just make sure all of them are placed back in the set nice and tight when you get your board back.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
