I have a 50 inch plasma that I suspect the Y-sus has gone bad
When powering up the set up the screen will light up for less than a second. then go black. you can also hear the y-sus start to hum. then stop at the same time. I also observed the VSC and VY voltage rise a bit, then drop down to close to 0V.
The TCON boards buzzes vary by jumping the test pins on the TCON board. This board should be fine.
unplugging the YSUS <-> TCON connection causes the set to do nothing upon power up. All other disconnections do not change the original symptoms.
Am I on the right page? YSUS for these are pricey. I want to be sure before I pull the trigger. Component repair would be ideal.
http://imgur.com/a/TYzxf
I will attach pictures in thread when I am able
