Samsung ps42q96hd Panel replacment
  • Diceaster21
    • Feb 2013
    • 5
    • United Kingdom
    Just a little over three months ago I brought a Samsung ps42q96hd from an auction, It had a small crack in the screen but not enough damaged to effect the picture.
    After about two months I started to get black lines coming from the damaged area going across horizontally on the screen, now it has finally opened up and the screen Is dead just a strobe effect with a burnt image on the screen.
    Now I have access to another model of the TV It's a Samsung ps42q97hd with the clicking issue.
    So would I be able to use the plasma panel from the ps42q97hd, to use in the ps42q96hd.
    Any help would be great, Will
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung ps42q96hd Panel replacment
    Yes you can use them panels even if the Sus boards are different they work
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      The reason why the black lins form is because the gases for them rows have leaked out meaning that the Sus boards can not longer scan the rows because they are not completed.
      • sordids999
        • May 2013
        • 2152
        Im not sure they will be interchangeable but i might be wrong so ill wait until someone else joins in
        why dont you fix the Q97 ?
        plus i think i have a few screens spare all working just been stripped down Q96 AND Q97
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          They are Sordids trust me
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Also the Q97 is an easy fix probably just broken solder joints or some bad caps ! The power supplies are the same though so just swap them out.
            • sordids999
              • May 2013
              • 2152
              Originally posted by reeceyburger123
              they are sordids trust me
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Honestly trust the 16 Y/O haha seriously though I have servied alot of them and dont a few mods so to speak lol
                • Diceaster21
                  • Feb 2013
                  • 5
                  • United Kingdom
                  Thank you for all the responses this is going to help me out alot.
                  • howardc64
                    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                    by howardc64
                    • Prior owner tried a replacement main board. No difference.
                    • Samsung 2x red blinking standby LED = panel fault
                    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                    07-19-2025, 10:54 PM
                    09-07-2024, 05:50 AM
                  • triplefour
                    SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
                    by triplefour
                    TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
                    tcon is built into mainboard.
                    Only one cable goes to panel boards.
                    there is a cable from one panel board to the other that links them.
                    cost cutting measure that results in us having harder time to diagnose.
                    removing the link to the second panel board allows TV to stay on with stable backlight but no image.
                    used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
                    07-28-2022, 07:59 PM
                  • NWArkGuy
                    Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                    by NWArkGuy
                    Well, I will be the first to admit that I screwed up...
                    In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                    I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                    I have 2 that I have found and have in my possession. ...
                    10-12-2023, 10:13 PM
                  • KYBOSH
                    Samsung UN50TU8000 - Dead Panel Forensic Questions
                    by KYBOSH
                    I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
                    When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
                    When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
                    Later I checked for shorts on the panel PCB boards but could not find anything.
                    When I took a look with the FLIR i noticed the 2 resistors...
                    08-10-2024, 08:39 AM
