What causes this? Sharp lc50lb370u
+ More Options
Posts
  • sleepingciv
    • Nov 2015
    • 9
    Just noticed this last night. Tv is brand new. Less than a month old.
    The black curved lines.
  • truep
    • Aug 2010
    • 373
    Re: What causes this? Sharp lc50lb370u
    Looks to me like it was the source, not the TV.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Is it like than on all sources ?
      • sleepingciv
        • Nov 2015
        • 9
        It does it on normal tv, Netflix ect ect. Doesn't go away.
        • sleepingciv
          • Nov 2015
          • 9
          It seems the screen is loose not tight up against the frame if that might matter
          • budwich
            • Jul 2015
            • 3097
            My take is that the frame or screen edge mounting is bent or something is in between the bezel and panel causing extra pressure on the LCD screen in that area.
            • advant
              by advant
              02-03-2020, 12:25 AM
            • sefoster
              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
              by sefoster
              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
              11-20-2022, 09:29 AM
            • gavenb
              Sharp LC-80LE661U 80 inch
              by gavenb
              Hi folks!
              I have a LC-80LE661U that had some interesting issues.
              Initially, it would come on and show the sharp logo and would show normal static before shutting off.
              I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
              11-12-2023, 02:05 PM
            • SONY_E-WASTER
              Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
              by SONY_E-WASTER
              Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
              The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
              then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
              does...
              12-26-2021, 05:46 PM
            • Superbee_dad
              Sharp 80” long short flash backlight error - Help
              by Superbee_dad
              Hello Sharp TV experts
              Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
              > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
              > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
              01-24-2025, 11:51 PM
