HISENSE 32D12 32" LED TV caps needed
  • ec8
    • Jan 2016
    • 3
    Hi All,
    I have a 32" Hisense LED tv that no longer turns on. The red standby light turns blue after hitting the power button but then after a few seconds goes red again.
    I removed the back of the tv and see two caps that are bulging up top. I'm guessing these are the cause? The two in question are the green caps labeled with only "CD286 VENT +105C F5".
    I don't seem to be able to find these exact ones for sale online but then again i'm not capacitor expert. Any insight is appreciated.
    Thank you!
    Ed
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: HISENSE 32D12 32" LED TV caps needed
    need pull them up to read the value...
    • kingjafad
      • Jul 2016
      • 8
      • england
      OP, Did you ever replace those capacitors and did it fix the problem? My son has a LOGIK L22FE12 (Curry's UK brand) with the same power problem, blue power light with nothing on the screen, then turns to red standby. I took the back off the TV and the same capacitor as yours is bulging (CD286 VENT 105c F5) which is a 2200uF 10V. I proved it was the circuit board and not the back light by disconnecting the signal ribbon cable to the actual screen and powering on, it turned on and stayed on (blue light) with the backlights on full brightness proving the screen was fine. With the ribbon plugged in, i get the same symptom as yourself. I have ordered a replacement cap, but wanted to ask if you managed to fix it too?
      Thanks,
      Phil
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Replace the caps and see what happens Phil if not we will help further
        But whatever you do dont be like the guy who started this post and not update us, I want to slowly impale him for not doing that.
        • kingjafad
          • Jul 2016
          • 8
          • england
          Reecey, thanks for the reply. I decided to pop up to maplins rather than wait for the part from china! So i paid 99p for the nearest cap in maplins which was 2200uF 16V, and it is physically about the same size (if a smidge bigger) than the original 10V one but it works perfectly and I can chalk the job up to another win for my radar techie training
          For the benefit of others looking to see what the visual indication on the cap prompted me to feel it was the cause, it was only a very small buldge on the top, I have 2 pics of the failed cap to demonstrate (the gunk on the second picture is the glue holding the cap to the board, not anything from the cap itself). Also the 3rd pic is the original cap in position on the pcb incase others find it helpful for their own repairs.
          Many thanks,
          Phil
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Cool is the issue sorted now buddy ?
            • kingjafad
              • Jul 2016
              • 8
              • england
              Yes all fixed, my son was over the moon, he can get back to his PS4 on this lovely Sunny Sunday now! Grrrr
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Good work matey I would say replace the others but they will probably last a while longer. Btw have you any images of the replaced cap or not ?
                • kingjafad
                  • Jul 2016
                  • 8
                  • england
                  Sorry, I didn't take any picture of the fixed version as i put it back together straight away. Although it was this one in maplin http://www.maplin.co.uk/p/2200f-16v-...apacitor-n12eb but the colour of it was a brown/black not red/pink as in the advert.
                  Thanks, Phil
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ok no worries thanks for the update and glad its sorted also be sure to turn the backlight down to 5 or so as well stop the Leds burning out
                    • Masky
                      • Aug 2018
                      • Russia
                      Hi people. I'm from Russia. I had the same problem with my TV. If I take him to the service center, I will pay 1500-3000 rubles. I went to radioshop and bought 2 hats in 0.3 rubles. After his replacement, my TV came to life
                      Thank's you)))
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • USmechS
                        Hisense 65H6570F Logo shows then turns off
                        by USmechS
                        Hello everybody,
                        I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
                        Things I have done:
                        A. Plug it off and on.
                        B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
                        C. Contacted the customer service, They sent me a firmware update, with the file name:
                        upgrade_loader_no_tvcertificate.pkg
                        The zip file has this...
                        04-25-2022, 03:06 PM
                        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                        by momaka
                        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                        Macron Power Technology Co. LTD.
                        Let’s look at the PSU itself.
                        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                        06-02-2021, 10:05 PM
                      • reessi
                        Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                        by reessi
                        Hello:
                        I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                        I started on the ACER:
                        Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                        All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                        I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                        10-29-2024, 11:31 AM
