Bush LED24265DVDCNTDW
  • Puhmik
    • Aug 2015
    Hi there,
    I am looking for firmware for LED TV. It is 24 inches TV with DVD.
    Does somebody has this firmware?
    Main board is VESTEL 17MB95M
    Screen model: VES236WNVC-2D
    Supplay: 17IPS61-3
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Bush LED24265DVDCNTDW
    I have motherboard for the this Tv also look up 17MB95 core update and try that.
    • Puhmik
      • Aug 2015
      Can you dump firmware from this board?
      • michael dranfield
        • Jan 2016
        • 232
        • England
        Did you get this firmware ???
        • Bazilwrc164
          Request: Firmware for Hitachi 42HXT12U (Vestel 17MB95M, VES420UNDL Panel)
          by Bazilwrc164
          I’m looking for a USB firmware file or EEPROM dump for a Hitachi 42HXT12U TV.
          The mainboard is a Vestel 17MB95M, and the screen panel is VES420UNDL.
          I recently replaced the mainboard with another 17MB95M, but it’s programmed for an LC420DUJ panel, and I’m getting no picture. I’d like to flash the correct firmware via USB or update the EEPROM if needed.
          If anyone can provide:
          • A working USB firmware file (like upgrade_loader.pkg or mb95_m.bin)
          • Or a compatible EEPROM dump
          07-23-2025, 12:15 PM
        • zklgfs
          Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
          by zklgfs
          I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
          08-11-2025, 02:14 PM
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • gurj1979
          Ubiquiti firmware help. US-8-150W POE
          by gurj1979
          Hi guys.
          I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
          Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
          So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
          Got New chip and writes good.
          THE PROBLEM...
          It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
          Does anyone have a Good Firmware I can have?...
          07-22-2024, 05:13 PM
        • stav242
          BUSH DLED43IHDHDRS 17MB130S Firmware needed
          by stav242
          i have a BUSH DLED43IHDHDRS.
          the MB - 17MB130S is not booting - it did once then wont boot again.
          Suspect its the corrupt firmware issue.
          Where can i find the correct firmware for this model ?
          11-02-2022, 03:39 AM
