BUSH DLED43IHDHDRS 17MB130S Firmware needed
  • stav242
    • Jan 2014
    • 61
    i have a BUSH DLED43IHDHDRS.
    the MB - 17MB130S is not booting - it did once then wont boot again.
    Suspect its the corrupt firmware issue.
    Where can i find the correct firmware for this model ?
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: BUSH DLED43IHDHDRS 17MB130S Firmware needed
    what lcd screen number is used in this tv (it usually says on a white sticker)
    • yokoono
      • Apr 2010
      • 515
      DLED43IHDHDRS = DLED43UHDHDRS ?
      Panel VES430QNYB-2D-N01 ?.
      • Daniel Larsson
        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
        by Daniel Larsson
        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
        During these seconds the function button is not working...
        08-13-2025, 10:29 AM
      • EduCabral
        [Help Needed] Yatour YT-M06 (Pioneer 1) – Firmware or Schematic Request
        by EduCabral
        I'm currently working on reviving a Yatour YT-M06 CD Changer Emulator module for use with a Pioneer 1 interface (specifically with a DEH-P5950IB head unit).
        While the unit is recognized as a CD changer, none of the USB, SD, or AUX features respond, which leads me to believe the firmware may be corrupted or incompatible.
        🔧 Details:
        • Model: YT-M06
        • Interface: Pioneer 1
        • MCU: Fujitsu MB89F202
        • Goal: Find a valid .bin firmware file or memory dump from a working unit
        I'm happy to attempt flashing, analyzing memory dumps, or doing hardware-level...
        07-15-2025, 12:26 AM
      • Daniel Larsson
        Firmware file for Marantz NR1501 needed
        by Daniel Larsson
        I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
        After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
        The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
        The content of these seems to be useless as far...
        05-23-2025, 04:11 AM
      • PNI E.
        firmware hitachi 50hk6000 mainboard 17mb130s
        by PNI E.
        hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
        02-14-2025, 02:06 PM
      • jorpec
        Dump/Firmware needed TV Kunft 19CG86813 Board T.EME380.61 Panel ECG185BB-LC4
        by jorpec
        Hi, all
        I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
        10-17-2025, 03:51 AM
