Sharp Aquos 70" LED LC-70LE632U does not power on
Re: Sharp Aquos 70" LED LC-70LE632U does not power on
Diode D7951 is the half-wave rectifier, C7951 is the filter cap, this feed the 5V regulator IC7590 for the BU5V (STBY 5V) PD pin 15.
So did you lift one leg of the diode and retest it?
Sharp RUNTKA857WJQZ (DPS-222BP, 2950284203) Power Supply Unit
http://www.shopjimmy.com/sharp-runtk...pply-unit.htm#
Pictures provided by shopjimmy.Last edited by budm; 12-29-2015, 05:45 PM.Never stop learning
Does it matter which one end of the diode I desolder to test it?Comment
I uploaded the pix from SJ on post 22.Never stop learning
Desoldered one end of D7951 and it still measures 0.0 on the multimeter diode test. The following name is marked on the diode SB2100 (first row) and 050 (second row). Not sure of the letter 1 or I in "SB2100".Comment
SB2100:
Attached FilesLast edited by budm; 12-29-2015, 06:41 PM.Never stop learning
I cannot seem to find where to source this part online. Would it be available in a Radio Shack store?
Should I test more parts on the board while I source this diode?Comment
I doubt you will find this Diode at Radio Shack.
Good ideas to might as well test the other devices, you should resolder the transformer legs and devices mounted on the heatsink, you can see that they use the rivets for some of the legs which tend to have cold solder joints, make sure to use Flux.Never stop learning
You can get the sub from digikey, just have to match the spec, it will be faster but more expensive.Never stop learning
Good ideas to might as well test the other devices, you should resolder the transformer legs and devices mounted on the heatsink, you can see that they use the rivets for some of the legs which tend to have cold solder joints, make sure to use Flux.Comment
Ordered the diode, it will take 10-15 days for delivery.
When I get it, should I do the following?
- Desolder the old diode and remove it
- Cut the ends of the new diode to the same length as the old diode
- Orient the new diode the same way as the old diode and solder it
- Install the board
- Connect the cables back and plug in the power cord
Is there any thing else I need to know?
Budm: Thanks a lot for all your tutorials. Very well written. I read all your troubleshooting and getting started guides before I posted this thread. It was very helpful!
Thanks.Last edited by Teletubbie; 12-30-2015, 10:36 AM.Comment
You should make the diode legs longer so when it is mounted the body will be above the circuit board may be 1/4 inch or so to help aid cooling of the Diode, diode legs are part of the heatsinking.Never stop learning
Good find! Hopefully replacing the diode does the trick. I had seen some power supplies for the transformer get so hot that it makes other semiconductors around it like diodes and resistors overheat and they like to short circuit or openDid I leave the soldering iron on?Comment
- To desolder an existing diode from a board, do you heat the joint from the front side or the back side of the board to melt the solder? A youtube video said you should add some new solder to help desolder an existing component. Is this true?
- When you install a new diode, do you solder on the front side, back side or both?
I am fairly new to soldering. A couple of questions:- To desolder an existing diode from a board, do you heat the joint from the front side or the back side of the board to melt the solder? A youtube video said you should add some new solder to help desolder an existing component. Is this true?
It may be easier to clip the diode out and then just de solder the two small pieces left behind. Less metal and no diode eliminates the heat sinking ability and lets you get more heat to the solder joint.
When installing, if you get a good flow- you probably wont need to touch the front side, just the back.Last edited by calimark; 01-09-2016, 10:55 AM.Comment
If you don't have solder wick/solder sucker you can heat up the solder and stick a toothpick in it to create a hole. ( as the solder won't stick to wood ).I only repair Panasonic plasma tv's! Currently owning a TX-P55VT50 and still searching for a ZT60!Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
