Sharp Aquos 70" LED LC-70LE632U does not power on
  • stereojohn
    • Mar 2016
    • 11
    • canada
    #61
    Re: Sharp Aquos 70" LED LC-70LE632U does not power on
    Hi i will do that thanks yesterday i tried the codes freakaftr8 mentioned and got the set to power on the back lights for 2 seconds aggain but not i have picture and sound just no backlight and a constant inverted light so i am really happy now i know the lcd and t-con are good what a relief just got to figure why the 420 leds dont stay lit they all look perfect nice and bright ?
    • budwich
      • Jul 2015
      • 3097
      good, once you take the measurements especially around the inverters, you will likely find your problem... compare values across the inverters to see if there are any differences.
      • stereojohn
        • Mar 2016
        • 11
        • canada
        #63
        Hi i am looking but cant find anything defective or short ? having no diagram sure does not help ...this is not the simplest tv to fix for sure .
        • tilden
          • Oct 2016
          I've had the exact same issue with my TV and have taken out and tested the same diode and sure enough it is shorted when reading from either direction. Mine is a SB2100 133 instead of the SB2100 050 yours was, but I imagine the diode you used would work for mine? If so - do you still have any of those extras available and be willing to drop one in the mail to me?
          • Teletubbie
            • Dec 2015
            • 28
            I should have some spare diodes and I can mail one to you (I hope I can remember where I left). Send me your mailing address by PM. In fact, I am local to you in the triangle area.
            • tilden
              • Oct 2016
              I wasn't able to find an exact match to my SB2100 133, but I ordered this one from Mouser and swapped it in and my TV works great again.
              http://www.mouser.com/Search/Product...y750-SB2100E-G
              • spoon-man
                • Mar 2017
                I just wanted to chime in and say that you all are a bunch of steely-eyed electronics repairmen.
                I was able to pick one of these up for $100 because it wouldn't power on. Spent $2 getting parts, replaced D7951, and now it works like a charm! Thank you!
                • read-eval-print
                  • Aug 2023
                  • US
                  #68
                  I know this thread and this response are both a few years old, but I want to second this sentiment. I replaced the diode just as described, and it worked for me too. This saved my TV from recycling or a landfill and saved me several hundred dollars (at least) for a replacement. My utmost appreciation to you all.
                  • alsic16
                    • Oct 2023
                    Hey everyone, this is the ultimate thread that I've been using to troubleshoot my LC-70LE632U and I feel so close to the solution but need some help.
                    My set started throwing a 1-1 code recently. I'm able to boot into the K menu. Backlights turn off after ~10 minutes. Reset to factory, reset lamp, all that works fine. Every consecutive time I use the TV, the amount of time I have before it goes into an error state gets shorter. I've replaced the D7951 diode like everyone recommends to no avail. I bought an LED strip voltage tester and all of the strips seem to work fine at 181-183V isolated from the power board.
                    I'm at a loss for what to do next but hopefully y'all can point me in the right direction. Hopefully 7 years isn't too long a gap for fixing.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
