LG (lg42cs460) flickering backlight after being on for 2 - 3 hours
  • Seanl84
    • Dec 2015
    • 11
    • Ireland
    As above folks, new ccfl needed?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG (lg42cs460) flickering backlight after being on for 2 - 3 hours
    Check BL voltage and Inverter section. Could be a Hi-Volt Transformer breaking down with heat. All caps on PSU Ok?? Are voltages steady??
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • k24a1
      TongFang GK5CN5Z (CyberPowerPC Tracer III Xtreme) LCD backlight flickering
      by k24a1
      Hello, I have a strange issue with a laptop that I'm working on fixing up for a friend of mine, and it appears as though the LCD backlight control is not reliable. The LCD backlight flickers sometimes with inconsistent brightness. The controls are no better.. when I go 1/3 of the way in the brightness controls it will get bright but flicker quite obviously, and when I go all the way to what SHOULD be full brightness, it becomes darker. The flickering is less severe at lower brightness, but more severe at higher. the backlight will literally flicker on and off when I set it to the lowest brightness...
      06-11-2024, 05:45 PM
    • sliceypete
      Samsung LE52B620 - Flickering backlight
      by sliceypete
      Hello All,
      My Samsung LE52B620 started to have backlight flickering about a year ago, it would only last for about 10 mins and then the backlight would stay on.
      about a month ago the backlight flickering is constant and does not stop.
      I think it's a problem with the power supply board (BN44-00267b) or maybe the backlight is dying?
      I checked and all the caps look to be fine.
      I do not believe it is a problem with the mainboard, since I unplugged it from the power supply and the backlight came out but still flickers.
      08-04-2021, 05:11 AM
      Design of CCFL Backlight Inverters with Frame & Bar Cores
      Summary
      Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
      The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
      The frame and bar ferrite cores, described in this brochure, are especially designed...
      10-07-2024, 04:26 AM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
