LG 42LN5400 clicking sound when powered on
  • Gadjet
    • Aug 2012
    • 248
    There is a red standby light, when you power it on it flashes and the tv makes a clicking sound. However there is never a picture that shows. I have disconnected the y sus from the power supply and the clicking doesn't happen and the red standby goes out after powering on but still no picture or backlight. also disconnected the x sus board and reconnected the y sus clicking returns no other changes.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 42LN5400 clicking sound when powered on
    The Tv in the images is not a 42LN5400 ? I repaired a few of these shorted fets on the Ysus. Do you have a DMM ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      The Z/Xsus kills the Ymain in these, the copper coils on the Zsus break through the solder joints which kills the Ymain.
      • Gadjet
        • Aug 2012
        • 248
        Sorry your correct was looking at the wrong label, its a Zenith Z42PJ240
        • Gadjet
          • Aug 2012
          • 248
          So should I replace both the Y and x/z?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No cheaper and more reliable to repair them easy to do, also you will get some experience. You have a DMM ?
            • Gadjet
              • Aug 2012
              • 248
              yes i have one
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Right do you know how to find S\C ?
                • Alastair E
                  Chief Womble
                  • Mar 2013
                  • 1963
                  • U.K.
                  It'll be the two on the small heatsink in the middle and the two on the left-hand heatsink near the bottom.
                  Usually caused by one of the small ceramic caps going short near bottom of l/h heatsink.
                  Ive had two of these, both with that blue cap cracked or blown to bits.....
                  1N 1kV disc ceramic
                  IF you Dont replace that cap, It may last an hour or a month--but sooner or later, Bang again!
                  TELEFIX
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    1N 1kV disc ceramic
                    Not in my experience, the 30J124 or 30F124 fets go S/C when the coils on the Zsus break through the solder the ones I repaired have been gone for ages now (over 4 months), never seen that cap blown but will take note buddy chees
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Ive had a few fail like that. Sometimes the cap just cracks (The most 'dangerous') sometimes there's nothing left of it!
                      --Its the one directly opposite the bottom of the row of the wire end of the four elect-caps in centre of board.
                      Its best-case when the cap blows itself completely to oblivion--No chance of it ever shorting again.
                      --Its when it just cracks is when its sure to fail taking the four IGBT's and the 2.2 ohm with it....
                      This resistor is just by the Vs fuse on the board as I recall--Maybe the one near bottom--just check 'em, you'll know if its open, all you'll get on screen is a coloured mass of mal-discharge....
                      TELEFIX
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Hmm, I have seen repair kits that have a 2.2ohm resistor in them but the ones I had in to fix that resistor was fine, maybe a combination of problems that cause the Ysus to have a meltdown. Also I always see them 30F & 30J transistors randomly blowing on quite a few different Tvs seen it on Samsungs and Lgs quite often.
                        • Alastair E
                          Chief Womble
                          • Mar 2013
                          • 1963
                          • U.K.
                          Usually used in the SUS_Up/SUS_Dn so are under a lot of stress.....
                          I bought a truckload of 'em!
                          TELEFIX
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Yep normally them that fail, I have also replaced alot. Good job they are cheap to obtain though.
                            • Gadjet
                              • Aug 2012
                              • 248
                              not sure what s /c stands for?
                                Short Circuit.
                                • Gadjet
                                  • Aug 2012
                                  • 248
                                  ok so i examined the board and this is what i found on the back of the ysus.
                                  • B0r1s
                                    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                    by B0r1s
                                    PSU - BN44-00878A
                                    Symptoms:
                                    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                    A weak clicking sound was coming from the transformer.
                                    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                    Progress:
                                    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                    01-17-2023, 04:58 PM
                                  • slimmy182
                                    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                    by slimmy182
                                    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                    Looking on google I found this:...
                                    01-14-2023, 11:55 AM
                                  • Solvik
                                    XFX XPS 650w 3XS PSU making Ticking/clicking sound
                                    by Solvik
                                    Hello
                                    i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
                                    All voltages are normal....
                                    02-13-2025, 02:43 PM
                                  • Sisko
                                    Onkyo-593 No power and now clicking sound
                                    by Sisko
                                    Hi all!!
                                    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                    10-03-2025, 02:18 PM
                                  • nbnb
                                    Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
                                    by nbnb
                                    I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
                                    Any idea what is causing the clicking sound? Any easy way to...
                                    11-23-2019, 12:03 PM
