There is a red standby light, when you power it on it flashes and the tv makes a clicking sound. However there is never a picture that shows. I have disconnected the y sus from the power supply and the clicking doesn't happen and the red standby goes out after powering on but still no picture or backlight. also disconnected the x sus board and reconnected the y sus clicking returns no other changes.
LG 42LN5400 clicking sound when powered on
Re: LG 42LN5400 clicking sound when powered on
The Tv in the images is not a 42LN5400 ? I repaired a few of these shorted fets on the Ysus. Do you have a DMM ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/ -
The Z/Xsus kills the Ymain in these, the copper coils on the Zsus break through the solder joints which kills the Ymain.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
No cheaper and more reliable to repair them easy to do, also you will get some experience. You have a DMM ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Right do you know how to find S\C ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
It'll be the two on the small heatsink in the middle and the two on the left-hand heatsink near the bottom.
Usually caused by one of the small ceramic caps going short near bottom of l/h heatsink.
Ive had two of these, both with that blue cap cracked or blown to bits.....
1N 1kV disc ceramic
IF you Dont replace that cap, It may last an hour or a month--but sooner or later, Bang again!Last edited by Alastair E; 12-26-2015, 05:03 PM.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
1N 1kV disc ceramic
IF you Dont replace that cap, It may last an hour or a month--but sooner or later, Bang again!Last edited by ReeceyBurger123; 12-26-2015, 05:33 PM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Ive had a few fail like that. Sometimes the cap just cracks (The most 'dangerous') sometimes there's nothing left of it!
--Its the one directly opposite the bottom of the row of the wire end of the four elect-caps in centre of board.
Its best-case when the cap blows itself completely to oblivion--No chance of it ever shorting again.
--Its when it just cracks is when its sure to fail taking the four IGBT's and the 2.2 ohm with it....
This resistor is just by the Vs fuse on the board as I recall--Maybe the one near bottom--just check 'em, you'll know if its open, all you'll get on screen is a coloured mass of mal-discharge....Last edited by Alastair E; 12-26-2015, 05:41 PM.TELEFIX
Hmm, I have seen repair kits that have a 2.2ohm resistor in them but the ones I had in to fix that resistor was fine, maybe a combination of problems that cause the Ysus to have a meltdown. Also I always see them 30F & 30J transistors randomly blowing on quite a few different Tvs seen it on Samsungs and Lgs quite often.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Usually used in the SUS_Up/SUS_Dn so are under a lot of stress.....
I bought a truckload of 'em!TELEFIX
Yep normally them that fail, I have also replaced alot. Good job they are cheap to obtain though.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Short Circuit.Never stop learning
by B0r1sPSU - BN44-00878A
Symptoms:
The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
A weak clicking sound was coming from the transformer.
Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
Progress:
After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I... -
by slimmy182Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
Looking on google I found this:... -
by SolvikHello
i have a older powersupply from XFX that makes this wierd electronic ticking /clicking noise. Its not the fan thats making the sound. See video below. Is anyone familiar with what component this sound can come from?
All voltages are normal.... -
by nbnbI have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
Any idea what is causing the clicking sound? Any easy way to... -
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
- Loading...
