Sansui SV-PD403
+ More Options
Posts
  • burntfingers
    • Jan 2011
    • 148
    Sansui SV-PD403
    Set does not turn on.
    When pressed, Standby light flashes blue some six or seven times and returns to yellow.
    Nothing else happens.
    Checked for dry joints, bad caps, plugs, visually there's nothing wrong.
    Can't find the diagram, also.
    Y and X boards look good.
    Tried to unplug some power plugs, nothing.
    Have you had this set here before?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sansui SV-PD403
    Checked all fuses on Psu ?
    • burntfingers
      • Jan 2011
      • 148
      Re: Sansui SV-PD403
      Only found two, OK - one in the mains entrance and another round one on the PS.
      Are there more?
      Something is not helping the two mains relays [for AC] to close and "fire" the set.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: Sansui SV-PD403
        Ok, need close up images of the Psu.
        • burntfingers
          • Jan 2011
          • 148
          Re: Sansui SV-PD403
          OK, here are three new pictures of Power Supply board - one taken on its length, the other two half of its height each.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: Sansui SV-PD403
            Ok right do you get Vs & Va voltages when you try to turn the Tv on ?
            • burntfingers
              • Jan 2011
              • 148
              Re: Sansui SV-PD403
              They both read zero volts at switching on.
              I only get one of the 5 volts, nothing else.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Re: Sansui SV-PD403
                Right ok, do you know how to check resistors ?
                • burntfingers
                  • Jan 2011
                  • 148
                  Re: Sansui SV-PD403
                  I do, and already checked the high wattage ones, they are OK.
                  Didn't find any fuse ones, couldn't find any.
                  The power can only come on after the two relays are activated.
                  Could I bridge them to see if I get power?...
                  • burntfingers
                    • Jan 2011
                    • 148
                    Re: Sansui SV-PD403
                    I've been looking for the service diagram, but so far no luck.
                    Does anybody have it?
                    • fzabkar
                      • Mar 2009
                      • 772
                      Re: Sansui SV-PD403
                      Here is a [blurry] PSU circuit diagram from a Konka PW-1450:
                      Perhaps the flash codes will be similar to those of other Konka plasmas.
                      • burntfingers
                        • Jan 2011
                        • 148
                        Re: Sansui SV-PD403
                        Thank you.
                        This youtube video suggests it could be a thermal fuse under the switch mode power transformer.
                        Going to investigate it.
                        [Diagram, unfortunately, not clear enough to read values]|
                        https://www.youtube.com/watch?v=qQ_iLxx3Fj4
                        • Mgiffune
                          by Mgiffune
                          I have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started β€˜fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
                          I ordered a supposedly β€˜new' Tcon board this time, and
                          06-09-2024, 10:28 AM
                        • Hornnumb2
                          Sansui sled4019 dim picture
                          by Hornnumb2
                          I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
                          08-31-2025, 10:37 PM
                        • Hornnumb2
                          by Hornnumb2
                        • Neddsme
                          SANSUI SLEDSC-32HD TV not booting, No stand-by led
                          by Neddsme
                          I have a 32 inch Sansui android TV that stopped booting. i checked the motherboard for any power failures but it seemed OK to the best of my knowledge. The TV does not have a dedicated power supply board so i could not do any isolation but here is a list of all the things i think were relevant to test.
                          if i missed anything you let me know;
                          DDR (1.5V) = 1.484V
                          VDDC = 1.000V
                          VDDC_CPU = 1.151V
                          VDD1V2_DM = 0.000V
                          3V3_STB = 3.315V
                          3V3_M = 3.307V
                          1.8V_M = 1.803V
                          ALL KEYS = 3.310V
                          5V_STB = 5.142V
                          5V ...
                          11-02-2023, 01:33 PM
                        • trunguntilyou
                          Inspiron 5406 If the device only plugs in the battery, the device will not turn on
                          by trunguntilyou
                          Most of my devices cannot turn on with the battery (sometimes they still turn on). When I plug in the charger or both, it turns on normally. When I plug in the battery, it turns on and has 3v, 5v, 1.8v, (when each battery is not turned on, there will not be these 3 sources). In addition, there is no power even though Anyway, now I just need to plug in the charger, and the device will automatically turn on and turn on normally
                          st H0ZTM93
                          19860-1
                          Link to boardview/schematic - https://www.badcaps.net/forum/showthread.php?t=119432
                          Reminder: rules and organization...
                          10-22-2023, 10:51 PM
