SANSUI SLEDSC-32HD TV not booting, No stand-by led
  • Neddsme
    • Sep 2021
    • 30
    • Malawi
    I have a 32 inch Sansui android TV that stopped booting. i checked the motherboard for any power failures but it seemed OK to the best of my knowledge. The TV does not have a dedicated power supply board so i could not do any isolation but here is a list of all the things i think were relevant to test.
    if i missed anything you let me know;
    DDR (1.5V) = 1.484V
    VDDC = 1.000V
    VDDC_CPU = 1.151V
    VDD1V2_DM = 0.000V
    3V3_STB = 3.315V
    3V3_M = 3.307V
    1.8V_M = 1.803V
    ALL KEYS = 3.310V
    5V_STB = 5.142V
    5V = 5.140V
    RED = 1.313V
    GRN = 0.000V
    IR = 4.060V
    12V = 12.130V
    BCKLT = 0.000V
    VCC to LCD board = 0.000V
    so far this is what i was able to measure on test points and caps. The VCC to LCD was measured on the single cable that goes to the LCD flex board, on 3 Red wires that seemed to be the power wires.
    So far pressing the power switch, the 3.3v signal gets pulled-low normally, but nothing happens. there is no backlight, no turning on/off of stand-by light, no indication of anything happening. anything to do with the LCD or power-on sequence does not happen.
    There was some indication of some software update prompts months prior to the eventual state. but i havent tried any flashing/ software related things.
    this is my first encounter with a bricked android TV so any help would be much appreciated.
  • Neddsme
    • Sep 2021
    • 30
    • Malawi
    Re: SANSUI SLEDSC-32HD TV not booting, No stand-by led
    DDR (1.5V) = 1.484V
    VDDC = 1.000V
    VDDC_CPU = 1.151V
    VDD1V2_DM = 0.000V
    3V3_STB = 3.315V
    3V3_M = 3.307V
    1.8V_M = 1.803V
    ALL KEYS = 3.310V
    5V_STB = 5.142V
    5V = 5.140V
    RED = 1.313V
    GRN = 0.000V
    IR = 4.060V
    12V = 12.130V
    BCKLT = 0.000V
    update on the board, Turns out the board is identified as TP.MS338.PB802
    An android TV board with 4GB storage.
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
    • Grut
      JVC LT-39CA120 - Vestel 17MB171 - Android boot loop
      by Grut
      My JVC (Vestel) LED TV is stuck on a Android boot loop when I switch the power on.
      Previously, I was trying to clean the storage memory (by deleting as many files as possible), I may have delete some start-up Android files.....so I screw it.🤡
      When I switch the power on, the initial JVC is shown. I have tried to run Android 9 from a bootable USB on the TV. It starts reading the USB but nothing happens and the JVC logo and Android boot loop keeps the same.
      Can anybody help me please finding the 17MB171 USB firmware to try to upload...
      11-15-2024, 03:12 AM
    • Crystaleyes
      Samsung BN44-00259A standby question
      by Crystaleyes
      Hi all.
      I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
      SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
      Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
      The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
      08-11-2023, 05:15 AM
    • Aeisens
      Samsung UE50RU7170 not booting /no picture
      by Aeisens
      Dear all,
      My issue is the following:
      Tv suddenly started to make Strange things and went out. After disconnecting power and restarting, it tried to start but failed. After each attempt it got worse and worse. Now only the Stdb light is on and it is not booting.
      I checked the power supply -> Backlight on when disconnected from mainboard, so I guess Power supply is ok.
      Additionally the upper right part of the main-board makes some whistling noise -> probably issue there and therefore issues with booting
      Question 1: Where should I start to...
      06-24-2025, 03:07 PM
