Thru Hole Diode markings
  • tech2014
    • Aug 2014
    • 807
    Hi guys, I need to identify some diodes that I need to get the part numbers for. They are very small and have numbers on them. See pic below. Is there a marking code book for these parts. I'm pretty sure they are zeners, but I need a part number.
    • 31087
    Re: Thru Hole Diode markings
    so what does it say on it.
    • tech2014
      • Aug 2014
      • 807
      They are B52,424,B12
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I wonder if that is one of those gas fuses?
          Can we see the board and the location of these devices?
          • petehall347
            diode identification please markings are SA then under it is 39
            by petehall347
            smd package .measures roughly 4x2 mm so thinking its DO-214AC markings are SA then under it is 39 .i believe 39 to be the date code .
            will see if suggestions are same as what i think it might be .
            07-18-2023, 05:05 AM
          • asr
            Finding replacement diode iPad Pro 3rd gen A1701
            by asr
            Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
            Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
            07-09-2024, 06:24 PM
          • unimatrix93
            TV backlight zener diode
            by unimatrix93
            Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
            So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
            Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
            The led strips has 9 6V leds.
            02-10-2025, 12:13 PM
          • nobbnobb1
            Bose Acoustimass 10 IV Subwoofer No Sound. Help with burnt component identification?
            by nobbnobb1
            I picked up this used Bose Acoustimass 10 IV speaker system. Speakers seem to work fine, but the subwoofer does not make any noise. So I took apart the unit and found some obviously failed (burnt) components:
            - 1x 3.14 A @ 250V main circuit fuse
            - 1x bridge rectifier GBU601. there's actually two of these on the board, one is obviously burnt and the other does not seem to have any anomalies like shorts. However I figure may as well replace both.
            - 2x diode. This is tricky because the only markings I see on it are: "617 402". No current rating or anything else....
            11-16-2024, 09:56 PM
          • NicRac
            monowheel repair,Is the diode the problem?
            by NicRac
            Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
            First of all, I am new here. Therefore I will shortly introduce myself.
            I am Nico and currently I study Physics.
            In my freetime I like to build and repair stuff. Especially big battery's.
            A few years ago I got myself an electric unicycle, monowheel or however you call that.
            The battery bms was broken so I replaced and resolder that. Nothing big.
            I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
            07-26-2024, 06:13 AM
