Haier 42EP24S plasma
  • olivercan
    • Mar 2008
    • 17
    I would like to know if somebody can help me with this tv,Haier it has sound but no picture,I read are there a kit for fix this problem .but want to know what part make this problem,I will apreciate your help Thanks
  • weirdlookinguy
    • Sep 2007
    • 1638
    Re: Haier 42EP24S plasma
    Pictures/Model Number/Link to the "Fix Kit"?
    • gonzo0815
      • Feb 2006
      • 1600
      http://www.fixya.com/support/t419278...a_pic_went_out
      • starfury1
        • May 2006
        • 1256
        well don't know whats in the kit...
        sounds like nothing a new TV wouldn't fix the problem
        (yeah I know bad joke...seems for the money they ask for these things they should come with 10 years free repair regardless of fault)
        found this post on what the kit consists of but I really have no idea
        http://catalog.ebay.com/Haier-42EP24...387511QQ_tabZ3
        Haier-42EP24S-42-in-EDTV-Ready-Plasma-Television
        Haier company did make a, what they call, 'Upgrade Kit' (TV-3940-01) to permanently repair the television and keep it that way. The Kit consists of the following:
        Control Board
        TV-5210-39, Y-SUS
        TV-5210-35, Z-SUSj
        TV-5210-37,
        New EPROM Chip 2006 version TV-2455-03,
        Upgrade Label TV-4050-08
        Haier Service Bulletin SB-TV-0003 containing the instructions to replace the boards yourself. Really isn't very hard. All you need is one tool, a screwdriver
        it was a personal ad so I just posted in the relevant bit.
        found this from gonzo's link on the upgrade code
        HTH
        Cheers
        You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
        • i4004
          • Oct 2006
          • 2029
          • olivercan
            • Mar 2008
            • 17
            I will like to know with part is the damage one .I dont think that all of the parts are damaged.i have some pictures so you guys can observe and tell me wich one i should replace.
            • weirdlookinguy
              • Sep 2007
              • 1638
              Wow... they actually used decent caps in the power supply. Dunno about the other boards though, can't really tell what they are.
              • Harvey
                • Apr 2007
                • 264
                R207 looks like its had a hole blown in the side of it, which if so would indicate a PSU fault. Other than that its imposable to tell from just photos.
                • starfury1
                  • May 2006
                  • 1256
                  I have absolutely no idea on this TV so the below is just my observations on the situation.
                  You would need a tech who actually know what the actual damage was that was done
                  it sounds like it might be common mode of failure if they made a kit for it.
                  you have with this also,
                  some faults may have the same root cause but its possible the damaged components might not be the same.
                  so you would have to hope that it causes the same component to fail to do a blind replacement of parts.
                  Unfortunately since they are doing it as PCB replacements
                  (which is the way a lot of things tend to be done repair wise these days (Sadly) )
                  As Harvey said from photos you just cant tell,
                  depending on the fault (or possibly faults here)
                  A component can fail and LOOK fine
                  Without Electronics knowledge and skills in trouble shooting
                  your best bet is the PCB kit (probably refurbished PCBs)
                  Sometimes things are just lemons and come out with faults unknown to the manufacture at the time
                  Since the kit mention a possible service note there could be a few component circuit changes on the PCB.
                  not that I am any guru on PCB manufacture
                  but the PSU doesn't look to be a crap built unit.
                  Please bear in mind were R 207 is in an area that you can consider as "deadly" as your house wiring
                  (some respects more so)
                  That cap is a 450V
                  I cropped and turned the image on it side and double the size
                  it looks like it to me too but that not to say it is only testing will for sure decided this
                  This could only be the start of your problems, you could have dead mosfet(s) and maybe that resistor saved it from burning up but its still faulty I don't know.
                  If you did managed to repair it "as it is now" there is obviously the danger that it will happen again anyway
                  This appears to be why the kit was release to solve the issue (or issues)
                  once and for all
                  it sounds to me like a PSU problem but from the kit things must run deeper then that only.
                  But then again I don't really know what involved in the kit
                  It sounds to me like you trying to save a few bucks by going to component level and there is nothing wrong with that idea
                  but you really need to know what you doing when you go to that level.
                  Without know exactly what needs to be done you might be better if you want to get it up and running buy a kit to repair it
                  Good luck
                  Cheers & welcome to the forums
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Your most probably faulty part is the hybrid IC on the ZSUS board. At least for similar TV`s this is the most common problem.
                    You can check this out by doing a continuity measurement between GND and SUS_Out or VS and SUS_Out. The associated pins should be labeled on the board.
                    You can check the fuse on the ZSUS board prior to this, if it is blown you may have an short at the 180v rail, either caused by the hybrid VR or by another component.
                    Sadly, the needed replacement parts don`t make it into most western countries.
                    Any way, this topic:
                    http://forum.iwenzo.de/reparatur-fla...82dbe89968fed1
                    in a German forum explains the basic schematic of a similar hybrid and how to rebuild it with more common components.
                    It was original for an YSUS board, but the hybrids are may be not that different.
                    At least the schematics should easily be understandable for any non German speaking people.
                    • gonzo0815
                      • Feb 2006
                      • 1600
                      EDIT:
                      The YSUS board is similarly build, it could may be the cause for your problems too.
                      All what is said about the ZSUS board is applicable to the ySUS board too.
                      • ArMaaN376
                        Samsung PS51E550 Plasma TV
                        by ArMaaN376
                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                        Opened TV cover & observed foll
                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                        How to confirm Y -Buffer board...
                        06-19-2024, 04:05 AM
                      • jm1234
                        Panasonic plasma TX-P42ST50 - 6 blinks
                        by jm1234
                        anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                        It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                        I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                        I checked that board for any obvious faults...
                        05-22-2024, 06:59 AM
                      • KYBOSH
                        Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                        by KYBOSH
                        Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                        No picture but you hear the TV static (white noise) playing loud and clear.
                        The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                        But it seems they didn't get too far and just left it.
                        When I first took a look I was amazed at how pristine the inside looked.
                        Its as if the TV had been in a time capsule.
                        Caps looked like they were just pulled off the self.
                        Copper coils had no sign of corrosion on...
                        02-01-2023, 11:10 PM
                      • alltvrepairs
                        Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                        by alltvrepairs
                        I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                        I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                        Any one met this problem in the past?...
                        Today, 07:34 AM
                      • chazh
                        LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                        by chazh
                        This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                        I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                        The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                        09-01-2025, 08:56 PM
