Vizio E420VL Logo then black problem and solution.
  • dabone
    • Aug 2010
    • 30
    I recently picked up a E420VL Vizio, with the following problem.
    It would power on, show the logo and then go to a black screen.
    After awhile, it would then show HDMI2 on the display, and then power off.
    I ordered an eeprom, and replaced it with no change in symptoms.
    I then found another thread and a video with it being the IR board.
    I unplugged the ir board and the tv is now working correctly.
    I've ordered a replacement ir board, and will post the results after I receive it.
    I'm posting this for other people to be able to find the solution if they also have the problem.
    Later,
    dabone
    Re: Vizio E420VL Logo then black problem and solution.
    Thanks for the info. Did you check the MLCC (Multi Layer Ceramic Capacitor) on the IR board to see if they are showing low resistance?
    • Super360
      Vizio E701i-A3 Vizio logo flashing then turns off
      by Super360
      Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
      07-25-2024, 07:06 PM
    • x_orange90_x
      Vizio V555-G1 stuck on wallpaper; now stuck on V logo
      by x_orange90_x
      I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
      12-28-2023, 06:26 AM
    • rajbot
      No Power problem with Vizio E60-E3
      by rajbot
      Hi all:
      I have a Vizio E60-E3 I am trying to troubleshoot a no power problem with. Thanks to the help on this board and elsewhere, I was pretty sure I had narrowed it to a power board problem. The board in question is a 09-60CAP0D0-00. Image attached for reference, but not of my board (tv is put away at the moment). FWIW, no obvious looking issues with the board.
      I measured voltage at power in and on the fuse and saw 120V, so power is getting to the board.
      On the pins out to the main board, I got no voltage at all on any of the pins. I assumed this...
      03-22-2023, 08:09 AM
    • MICHAEL_2013
      Change Logo Aptio Setup Utility 2021 (ROM Layout mismatch detected) Problem
      by MICHAEL_2013
      Good afternoon, Lords of great wisdom. My problem is the following: I bought a Chinese laptop with GN117_MB_V31-T board. (Aptio Setup Utility 2021) (There is no info for that board). And I want to change the logo of the bios. I have used Aptio_V Afuwin to do the bios Backup, then I change the logo with AMI ChangeLogo Tool v5.0.0.2 and everything seems perfect. But when you restart the new logo appears ok. But it automatically enters the bios, appearing a new option RECOVERY, ROM LAYOUT MISMATCH DETECTED - PARTIAL UPDATE IS NOT ALLOWED. If I give ESC it enters windows without problem but always...
      06-28-2021, 03:12 PM
    • Bob1394
      Vizio M65-C1 | Logo appears for 10 seconds then off
      by Bob1394
      I have used the search, and am stumped.
      My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
      I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
      https://www.badcaps.net/forum/showthread.php?t=81088
      https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
      Observations
      1) [Interaction] Power turned on via TV button (or remote)...
      02-08-2023, 01:03 PM
