SANYO DP19640 back light out...
  • RAMSELECTRONICS
    ATARI boy
    • Jul 2015
    • 48
    I have a SANYO DP19640.
    When I turn on it did turned on the back light then in few seconds then off the back light but I can bare to see the LCD screen seem working but no light..
    I opened back panel and I see the board has built in power supply and inverted together.
    See the pictures in attached files.
    I checked all caps are good...
    I suspecting the two chips something.. Q7004 and IC7001
    Any idea where caused the problem with back light? OR anyone have fixed it before?
    thanks!
    Re: SANYO DP19640 back light out...
    That MOSFET Q7004 got very hot, did you check the capacitance and ESR of the filter caps? Hopefully the Inverter transformer or the MOSFET is not damaged, you need to get the P/N of Q7004 to check the resistance between Source and Drain.
    If the lamps are worn out they can also cause too much current DRAIN, so there are many things you need to check.
    • RAMSELECTRONICS
      ATARI boy
      • Jul 2015
      • 48
      Okay thanks!! which Caps you want me to check? maybe you can circle on the picture.
      I see AliExpress sell the 20 Chips for $10.00
      thanks again!
        Did you get the P/N of Q7004? That should be checked first.
        • RAMSELECTRONICS
          ATARI boy
          • Jul 2015
          • 48
          Yup it's TPC8218 H
          Here what I found:
          http://www.aliexpress.com/item/TPC82...339305292.html
            TPC8218 Dual MOSFETs. Check the resistance between Source pins and Drain pins
            • RAMSELECTRONICS
              ATARI boy
              • Jul 2015
              • 48
              I measurement Source and Drain looks like all open.
              Of Course I desoldered the chip to out then measurement
              • RAMSELECTRONICS
                ATARI boy
                • Jul 2015
                • 48
                I am thinking to make different to the TO-220....
                Here for example: http://www.semicon.toshiba.co.jp/inf...&pid=TK72E08N1
                • RAMSELECTRONICS
                  ATARI boy
                  • Jul 2015
                  • 48
                  Back here again... I got new the Power Supply board from eBay and replaced it. but the issue are the same... uhhhh????
                  I saw on the screen when happening.... When I turned on the power, screen show "Please wait" show red then change to "HDMI" display show red become to white then picture looks great for less 3 seconds then back light shutdown but the green light still on and I hardly to see the screen picture is still there.
                  Possible bad CFL tube light inside the back-light? BUT short time turned on looks perfect??
                  thanks!
                  • RJARRRPCGP
                    • Jul 2004
                    • 6301
                    thanks!
                    Possibly a bad CCFL bulb.
                    I also saw a T5 fixture at HCRS with a bad T5 fluorescent tube do the same kind of thing.
                    Any bad fluorescent tube in the same circuit will result in the ballast also shutting off the good bulb, too!
                    ASRock B550 PG Velocita
                    Ryzen 9 "Vermeer" 5900X
                    Arc A770 16 GB
                    eVGA Supernova G3 750W
                    Alienware AW3423DWF OLED
                    • RAMSELECTRONICS
                      ATARI boy
                      • Jul 2015
                      • 48
                      Here I made a video... see the color.. red... then white... umm.. for sure bad one? where I get it.?
                      SHOOT video not working... let me try other way
                      • RAMSELECTRONICS
                        ATARI boy
                        • Jul 2015
                        • 48
                        Here
                        https://youtu.be/AGADb5_yIdE
                          You have bad lamp, you can also see the ends of the lamp are blackened. Do not keep on using it, it will draw too much current and take out the inverter transformer and the MOSFETs if the over current protection circuit does not kick in.
                          • RAMSELECTRONICS
                            ATARI boy
                            • Jul 2015
                            • 48
                            okay I will order new CCFL from eBay.
                            http://www.ebay.com/itm/2PCS-19-inch...EAAOSwR0JUUZ9p
                            • RAMSELECTRONICS
                              ATARI boy
                              • Jul 2015
                              • 48
                              Geez forgot leave a message.. I got replaced lamps and it's worked perfect! thanks!
                                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                by sam_sam_sam
                                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                I am comparing them to a brand new one that I installed
                                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                I going to let it run for several days before I remount back on the wall next to the...
                                09-05-2024, 06:48 PM
                              • PNI E.
                                tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                by PNI E.
                                hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                02-20-2025, 08:36 AM
                              • jdawg99
                                LG 47LA620V Same LED Failing Back Light Issues
                                by jdawg99
                                Hi All,
                                I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
                                04-23-2023, 01:04 PM
                              • boyebaran
                                hisense 65k560 back light problem
                                by boyebaran
                                hi to all
                                tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                                in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                                please advise me tnx
                                05-20-2025, 07:11 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
