55la6205 backlight issues
  • PNI E.
    tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
    by PNI E.
    hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
    02-20-2025, 08:36 AM
  • roy.zhero
    Sharp LC50LE752E no picture and backlight, indicator light is lit
    by roy.zhero
    I acquired a free 50” TV. IT is a Sharp LC50LE752E. It does not show a picture and has no backlight, although the indicator light turns blue meaning it has turned on.
    When power is plugged in, the indicator light will turn on blue, the backlight stays off and nothing is visible, even with a flashlight. When pressing the touch buttons on the tv nothing happens. When pressing buttons on the remote control the indicator light will blink indicating the IRsignal was received, but nothing happens.
    When I hold the force-on-combination it will turn on. It then shows a perfect...
    09-20-2020, 01:57 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • learnmore
    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
    by learnmore
    Hello Community!
    CASE DETAILS
    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
    Tried inserting firmware on USB and left it in for a few hours, but no change
    03-03-2024, 09:49 AM
  • koby058
    vostro comes up with back light but no picture
    by koby058
    Hi people!!
    The owner said it showed bad picture once in a while (attached)
    I see that there is back light but no picture.
    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
    Also attached schematic and BDV
    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
    07-13-2025, 01:03 PM
