samsung un50h6203af no picture but has sound
  • richardino
    • Jun 2012
    • usa
    Re: samsung un50h6203af no picture but has sound
    Originally posted by neilc6
    Got another one of these in with same symptoms. Model UN50H6400AF.
    Backlights working and no picture and 2 leds lit on tcon. Removed left side tcon connector and tv powered up right side with 3 leds on tcon. Covered about 4-5 pins on leftmost connector with scotch tape and tv powered up both sides.
    Question: Hi ! I did same method to mine. Coveres 5 pins of the FLEX CABLE and worked ! ( But with thin lines , like if resolution was somekind of incomplete ) Did yours have the same result or picture was perfect ? Thanks
    Best Regards
    Richard !
    • neilc6
      • Nov 2015
      • 1550
      You can try varying the number of pins blocked or try using better insulating tape like electrical tape.
      • TNKEG
        • Aug 2019
        May I ask for clarification? Are you talking about covering pins on the t-con output ribbon that corresponds with the blank half of the picture display?
        • neilc6
          • Nov 2015
          • 1550
          Yes. you are blocking the pins of the tcon ribbon cable at the outer edge on the bad side.
          Edit add: See this thread as well https://www.badcaps.net/forum/showthread.php?t=71885
          • TNKEG
            • Aug 2019
            Thank you sir.Someone gave us one of these rather expensive TV's because it has all the symptoms mentioned above.They thought maybe I could save it with hard headed tinkering and research.Before I did some intense forum reading, I replaced the t-con with no improvement, finding the same symptoms, only two LEDS lit on the t-con with both output ribbons hooked up and no picture, half screen picture with one ribbon. I have the main board on the way but after reading this and other similar posts, it just seems to me a manufacturers defect .I don't hold out a lot of hope for the main board.However,I am seeing low input voltages from the current main board to the t-con.That being said, maybe between this work around and the main board, I will get lucky.
            • neilc6
              • Nov 2015
              • 1550
              Replacement main board isnt going to fix this. You confirmed the main board is good when you connected half the panel and got a good picture. Only 2 out 3 leds lit on the tcon and good half screen confirms a panel fault.
              • TNKEG
                • Aug 2019
                You were correct sir.I had ordered the main board before finding this work around.The main board did not solve it.I am pleased to say however that the tape remedy worked.I may have more connectors than needed covered but I have a good picture, so leaving it alone.
                • alfatv
                  • Sep 2020
                  • 353
                  I guess my case is more difficult.
                  The 3rd AVDD LED blinks when either side is connected. And it's On when both sides are disconnected.
                  Probing AVDD to ground on panel boards in diode mode shows 1.1-1.3V on each side, everything disconnected.
                  Used LED tester to inject some current thinking that it will generate some heat in shorted component. Tried up to 10V/100mA, Eventually current drops to 20mA, does the same thing on each side, but it doesn't really solve anything, it then goes back to the original state. No signs of heat anywhere, feels like the panel is shorted,
                  • howardc64
                    • Jun 2017
                    • 651
                    Saved another one with electric tape on most outer contacts on the t-con to panel flex on the bad 1/2 of the panel.
                    - Covered line 1-2, 1-3, 1-4 resulted in horizontal line ~ 2/3 cross on top along with few lines of flickering brightness depending on content.
                    - Covered pin 2-6 (I think 5 pins total) make it work perfect. Skipped 1 as it seems to be not connected on t-con on the top side anyways.
                    - Adding electrical tape makes it hard to push and seat flex cable completely and can slide the tape back exposing the contacts if not careful. Mine was just tiny bit outwards but secured fine with connector closed.
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
                    • JohnML1975
                      Samsung UA50TU8000W no picture and no sound
                      by JohnML1975
                      Hello All
                      have seen posts on this model in here but my problem sounded different so thought i would create a thread
                      TV will not turn on
                      There is no standby light
                      When I press ON button for remote the red standby light does flash but no picture and no sound
                      From the back of the TV I can see the red light on the back of the mother board
                      Holding torch to the screen I cannot see a picture
                      I removed the back cover
                      Observing the boards I cannot see any damage
                      I disconnected the main board from the power supply
                      the back...
                      08-30-2025, 09:40 PM
                    • marekk
                      Samsung QE55Q67RAT no sound and bad picture when streaming
                      by marekk
                      I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                      I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                      Mainboard is based on pcb BN41-02695A BN94-14007B
                      I will appreciate any help
                      Many thanks
                      Marek...
                      05-29-2025, 02:23 AM
