Re: Vizio E470VL NO Backlight help
You do have the command signals to turn on the backlights circuit, and if you do not even see the backlights flash on for second before going into shutdown then you need to start looking in the inverter section starting by to see if there is any fuse/fusible resistor for feeding the Boosted B+ to inverter section or not, visual inspection, etc. just use logical step in troubleshooting.
