lg 32lv375s no backlight no picture
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Hi
    I have checked the power board (no desoldering), and everything seems to be OK ...
    Anyone have a schematic of this board (EAX62865601/7) ?
    Or anyone knows how to solve it ?
    Btw. what pins do I have to short to power up the board (PWR-ON with 24 or GND) ?
    thx
  • Hamie
    • Apr 2014
    • 1383
    Re: lg 32lv375s no backlight no picture
    Photos might help.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Photos and have you even checked the voltages labeled on the connector ?
      • nbdy
        • Aug 2015
        • 162
        • Croatia
        With what to connect the pwt-on
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          Sorry,was on a bussines trip ...
          here are the pictures :
          http://s1.postimg.org/3jnllwoa7/20151205_125710_1.jpg
          http://s24.postimg.org/nojsueoad/20151205_125719_1.jpg
          http://s4.postimg.org/51cw75hal/20151205_125730_1.jpg
          http://s8.postimg.org/v41u9om45/20151205_125817_1.jpg
          This are all 4 boards on the TV
          • nbdy
            • Aug 2015
            • 162
            • Croatia
            Hello,was on a long work out of home ...
            Checked the voltages,have 3.5V,but 12V and 24V not
            btw. the board looks ok like on the pictures no brown fluid around caps
            thx
            • nbdy
              • Aug 2015
              • 162
              • Croatia
              Rechecked the K10A60D, all ok with esr tester
              anyone an idea ??
              • CapLeaker
                Leaking Member
                • 8134
                First we need to know the DC voltages measured on the connectors of the power supply bottom right. Check if the power supply is getting turned on by the main board (PSon pin). Measure the pins and post voltages with corresponding pin names.
                If you have PSon and BLon, but no high voltage on the main filter caps, you either have a short in the secondary or the PFC isn't working.
                To check if the PFC is working, measure the DC voltage directly at the main filter cap. It should be around handy 400V. Be careful!
                No boosted voltage, no 12 / 24V.
                To fire up the PSU, take a 1k ohm resistor and jump between STBY voltage and PSon. Same thing for BLon.
                • nbdy
                  • Aug 2015
                  • 162
                  • Croatia
                  Sorry my work is on field outside my home,so can not reply over week ...
                  I mesure only the 3.5V on the white connector
                  the 24V is not present
                  PWR-ON is zero
                  BL-ON could not find on the board
                  where to measure on the main filter ???
                  thx
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Can you supply a closeup picture of the blue and white connector and the text written alongside giving the pinouts.
                    • i_am_hacked
                      • Mar 2016
                      • Saudia Arab
                      Hi everyone friends i am new to here and i want to learn about schematics how to check on voltage and find the problem please help me i have experience in hardware but no experience on pdf schematic who to troubleshot Thanks for everyone ...
                      • nbdy
                        • Aug 2015
                        • 162
                        • Croatia
                        http://postimg.org/image/5g2fw39mh/
                        rechecked the block capacitors,all OK,but the gretz don't have any voltage on middle pins,and side pins
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          Disconnect the white connector and check the power supply by connecting a 1K resistor from Power-On to 3.3V on the power supply white connector and check for 12V & 24V
                          • nbdy
                            • Aug 2015
                            • 162
                            • Croatia
                            With 1k resistor i have 12V and 24V on the pins and the 3.5V
                            • dick_barton
                              • Aug 2015
                              • 6642
                              • Wales
                              Remove the Power On pin carefully from the connector and plug the white connector back into the socket. Connect the loose wire to the 1K and connect to the 3.3V and check your backlights.
                              • nbdy
                                • Aug 2015
                                • 162
                                • Croatia
                                Still no backlight/no picture
                                the power led goes red,when i press ON the led flashes red and goes to orange
                                Could it be some other board,not the power supply
                                • Diah
                                  • Feb 2013
                                  • 6360
                                  is this your TV chassis LD12B main board EAX63557704 ?
                                  if yes then its not power supply, its main board which cant repair, only replacement
                                  • nbdy
                                    • Aug 2015
                                    • 162
                                    • Croatia
                                    Yes it is
                                    thx for reply
                                    • Diah
                                      • Feb 2013
                                      • 6360
                                      you can try also,this but not always work.
                                      take the black heat sink out, so you will have access to the DDR and processor , heat them with hotair gun on 350 degree for round 10 second.
                                      good luck
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        It does appear to be a main board problem as Diah indicates. I suppose you have nothing to lose to try and heat it as suggested.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
