lg 32lv375s no backlight no picture
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    Re: lg 32lv375s no backlight no picture
    Thx for advice ...
    Removed the heat sink,reflowed the processor (little flux on every side,and reheat with
    heat station)
    And a miracle it works ;-)
    thx all for advices and help
    • Diah
      • Feb 2013
      • 6614
      happy to hear that. cheers
      • coceicr
        • Feb 2013
        After years, reflow works for me too.
        Power source ok, all voltage ok, but no sound, no picture, no light.
        At power on, the relay click, led flash red slow twice, and that was all.
        Reflow (flux on all sides, heat 10-15sec with heat station, repozitioning
        the heat sink) and for naw it is ok.
        • videocentro
          • Nov 2020
          • 7
          • italia
          Hi.
          usually you need raball main micom, 90% solves.
          in some cases the micom p PAD are damaged and you will have to change the entire micom
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ermals
            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
            by ermals
            Hi all!
            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
            3. I've checked voltages...
            08-01-2022, 10:35 AM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
