How common is it for LEDs to short?
  • 120volts
    • Oct 2013
    • 57
    I'm a TV hoarder and I have 14 tvs in my shop right now.
    Plasmas are a pain but I like the picture.
    LCDs are a easer to work on.
    But now it seems to me that the LED back lit are a real problem.
    How common is it for the LEDs to fail?
    https://www.badcaps.net/forum/images/smilies/poof.gif
    Dan "TV Tinkerer"
    • 31185
    Re: How common is it for LEDs to short?
    shorts in leds are very rare,
    failure in general is more difficult to say - people dont bring us stuff that works!
    • 120volts
      • Oct 2013
      • 57
      Facebook is definitely a Bummer!
      Dan "TV Tinkerer"
        • 31185
        Facebook is just a cia tool to link you to your friends and to link your face to an i.p. address and name.
        think about how much the ability to put a face to an i.d. and group people into clusters is worth to an evil government!
        you could be walking down the street past some protest, police catch your face in a foto with the oher people.
        thanks to your driving license or passport they know your name, but thanks to facebook they also know who to connect you with!!!!
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
        • crea2k
          pioneer A-307R flashing leds on front panel, possible short
          by crea2k
          I have a pioneer A-307R here and what it does is flash all of the leds on the front and nothing more.
          I got the thermal camera out on it and saw that Q451 was getting hot, so I removed it and the lights now come on as normal, but obviously that part of the amp doesn't work.
          I tried replacing it, but it goes back to its flashing lights thing again.
          I noticed too that on the back of the board R465 - R467 - R 469 are all getting red hot (over 100 degrees C)
          Im guessing I have a short here somewhere, but so far I have not managed to find...
          10-05-2023, 03:51 PM
        • Stephen
          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
          by Stephen
          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
          02-06-2025, 12:03 PM
        • adelfr2009
          HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
          by adelfr2009
          I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
          After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
          09-28-2025, 10:21 PM
        • Pipolups
          Corsair K70 LUX RGB dying LEDs
          by Pipolups
          Hi there !
          I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
          Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
          10-08-2024, 11:58 AM
