Hi guys, picked this up this morning as spares / repair job, and it has no power what so ever. No standby.
Checked all fuses which are good.
So starting off on power supply, caps look ok but will test shortly. I'm thinking issue may be with bridge rectifier.
I have tested it in circuit and the 2 middle pins seems to be passing current both ways on multi meter in diode mode. The +/- seem ok as they only work one way but the two centre pins seems to be shorted.
Is it ok to test this in circuit or should I remove and test again?
Anything else I should check out?
