Samsung LED TV troubleshooting. Help is very appreciated!
  • Akoen
    • Jun 2015
    • 28
    • Danmark
    Re: Samsung LED TV troubleshooting. Help is very appreciated!
    Originally posted by budm
    'Pin 12 (BLU) = 0' So the main board is not sending the
    Backlights ON signal. We can force on manually.
    Thank you for your time!
    Okay how? By shorting some pins? Can this cause the power cycling?
    Does the other pins look correct?
    • Akoen
      • Jun 2015
      • 28
      • Danmark
      As far as i can tell BLU is connected to 13V through a resistor on the main board.
      • Akoen
        • Jun 2015
        • 28
        • Danmark
        Forget this! My bad...
        • Akoen
          • Jun 2015
          • 28
          • Danmark
          'Pin 12 (BLU) = 0' So the main board is not sending the Backlights ON signal. We can force on manually.
          I have tried to connect pin 12 (BLU) to 5 volts. This does turn on the backlight, but the television is still power cycling (meaning that the screen turns on and off and i can hear a relay clicking, in intervals of 2 seconds).
          • Akoen
            • Jun 2015
            • 28
            • Danmark
            It appears to be the PS pin that causes the power cycling. If i remove the PS pin from the connector the TV doesn't power cycle. But i Can still only turn the backlight on and OFF. Other functions isn't working. Any ideas?
            • Akoen
              • Jun 2015
              • 28
              • Danmark
              #26
              The PS pin is btw also called SW_PWR_OUT. So the main board is changing the State of this pin every 2 second.
              • Akoen
                • Jun 2015
                • 28
                • Danmark
                #27
                Is it at all possible to fix the main board?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Not understanding you too well, is the Pson going high then low ?
                  • Akoen
                    • Jun 2015
                    • 28
                    • Danmark
                    #29
                    Yes it is switching with 2 second intervals. And the "backlight on" is staying low.
                    • Akoen
                      • Jun 2015
                      • 28
                      • Danmark
                      #30
                      I still haven't solved the problem. Does anyone know a solution?
                      • comptek
                        • Aug 2013
                        • 606
                        #31
                        remove t-con cable "carefully" try that and all other boards and cables connected
                        • anmol
                          • Mar 2012
                          • 73
                          • India
                          #32
                          desolder blue and yellow wire and solder as this pic.
                          may be you have pin # 17 and pin # 18 have short circuit.
                          Regards.
                          • Akoen
                            • Jun 2015
                            • 28
                            • Danmark
                            #33
                            Thank you, but i have measured and the pins are not shorted.
                            • br777
                              • Sep 2017
                              • 21
                              • New Zealand
                              #34
                              Hi, I know this is an old thread...did you find a solution?
                              • Asraf Atb
                                by Asraf Atb
                                01-27-2025, 05:02 PM
                              • Lee M.
                                Samsung UN75RU8000FXZA bad main board?
                                by Lee M.
                                When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                11-08-2023, 07:46 PM
                              • jb_Bak
                                by jb_Bak
                                CN6401
                                Pin 01 NC
                                Pin 02 NC
                                Pin 03 "BL_ON": 0V
                                Pin 04 "N/C"
                                Pin 05 "STBY 3.3V": 3.5V
                                Pin 06 "GND": N/C
                                Pin 07 "AC_OFF"...
                                09-27-2021, 04:52 PM
                              • JDC
                                (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                by JDC
                                ONN 100012588
                                Issue: No Power, Then Rebooting After Main Board Change
                                Short answer: replace main board and power board
                                Technical answer: replace main board and Q306 & Q307 on power board.
                                Long answer:
                                TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                07-15-2022, 07:39 AM
                              • cheeky2
                                by cheeky2
                                05-25-2024, 03:27 AM
