Samsung LED TV troubleshooting. Help is very appreciated!
  • Akoen
    • Jun 2015
    • 28
    • Danmark
    Hello!
    I have a Samsung UE46ES8005 that won't turen on. The television is clicking and the screen stays blank.
    I have opened the television and tried to disconnect the power board from the main board. Result: The backlight can turn on and I Can measure 14V at the pins labeled 13V.
    I have also tried disconnecting all boards from the main board while the main board is connected to the power board. Result: The screen is Black, power board is clicking and the voltage switches between 0V and 14V.
    My question is now. Can i be sure it is the main board that is malfunctioning (and how to fix this) or could it be the TCON board?
    Mainboard: BN41-01800B
    TCON: BN41-01790C
    Power board: BN44-00522B
    Any ideas?
    Thank you in advance!
  • Akoen
    • Jun 2015
    • 28
    • Danmark
    Re: Samsung LED TV troubleshooting. Help is very appreciated!
    Here is a picture
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      https://m.youtube.com/watch?v=bJdDsxxxn2U
      Check this out mate.
        https://www.badcaps.net/forum/showpo...91&postcount=7
        • Akoen
          • Jun 2015
          • 28
          • Danmark
          Thank you very much! I will try to connect the cables directly!
          • Akoen
            • Jun 2015
            • 28
            • Danmark
            Thank you! I have just tried to solder a cable directly from the pads but without luck. The TV is just clicking and the voltage is switching between 0 and 5 volts
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Can you show us your soldering with pictures please ?
              • Akoen
                • Jun 2015
                • 28
                • Danmark
                Yes of course!
                • Akoen
                  • Jun 2015
                  • 28
                  • Danmark
                  And this
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    In the first picture them pins look shorted together, resolder them or check for continuity.
                      Can you pull the connector so we can see which pins are burnt up?
                      Also the new wires are in the way and they do not look like they are for the burnt out pins.
                      Straight shot pictures of the whole top and bottom sides of the power supply board?
                      • Akoen
                        • Jun 2015
                        • 28
                        • Danmark
                        I have attached the cables to two free pads on the same traces as the burnt out pins. There is no short so the failure is another place. Besides i Can measure a voltage switching between 0 and 5 volts on the mainboard at the right pins.
                        • Akoen
                          • Jun 2015
                          • 28
                          • Danmark
                          On the 5V pins i Can measure 6V in High State. I Can also measure a constant 6 V on the 5v condensator. Se picture. What Can cause this?
                          • Akoen
                            • Jun 2015
                            • 28
                            • Danmark
                            Here i measure the voltage
                            • Akoen
                              • Jun 2015
                              • 28
                              • Danmark
                              Never mind last picture. Meter was running low and showing odds voltages. I measure 5.3V on the 5V pin and 12.75V on the 13V pin
                              • Akoen
                                • Jun 2015
                                • 28
                                • Danmark
                                How Can i be sure that it is the main board that is faulty?
                                  'I have opened the television and tried to disconnect the power board from the main board. Result: The backlight can turn on and I Can measure 14V at the pins labeled 13V.' This already verify that the power supply and the LED driver are OK.
                                  So pin 17 and 19 are for the switched 5V, those two pins are electrically tied together.
                                  You need to report the DCV reading of those 20 pins in this format (TV is turned on) so we can see what is/are missing:
                                  Pin 1 (OD_LE) = xxV
                                  Pin 2 (PWM4) = xxV
                                  • Akoen
                                    • Jun 2015
                                    • 28
                                    • Danmark
                                    Pin 1 (OD_LE) = xxV
                                    Pin 2 (PWM4) = xxV
                                    Thank you. Here are my readings (measured on connector at the mainboard end). The power supply is switching between two states. The results in parentese illustrates the "off" state. Here pin 20 still has some voltage:
                                    Pin 1 (OD_LE) = 2.33V (0V)
                                    Pin 2 (PWM 4) = 0.69 (0V)
                                    Pin 3 (OD_ON) = 2.32V
                                    Pin 4 (PWM 3) = 0.69V (0V)
                                    Pin 5 (GND) = 0V
                                    Pin 6 (PWM 2) = 0.69V (0V)
                                    Pin 7 (B13V) = 12.74V (0V)
                                    Pin 8 (PWM 1) = 0.69V (0V)
                                    Pin 9 (B13V) = 12.74V (0V)
                                    Pin 10 (B13V) = 12.74V (0V)
                                    Pin 11 (Vamp) = 12.74 (0V)
                                    Pin 12 (BLU) = 0
                                    Pin 13 (Vamp) = 12.74V (0V)
                                    Pin 14 (GND) = 0V
                                    Pin 15 (GND) = 0V
                                    Pin 16 (GND) = 0V
                                    Pin 17 (B5V) = 5.3V (0V)
                                    Pin 18 (A5V) = 5.33V (0V)
                                    Pin 19 (B5V) = 5.3V (0V)
                                    Pin 20 (PS) = 5.29V (0.25V)
                                    If i disconnect power board an main board and measure directly on power board:
                                    Pin 1 (OD_LE) = 2.72V
                                    Pin 2 (PWM 4) = 3.19
                                    Pin 3 (OD_ON) = 2.71V
                                    Pin 4 (PWM 3) = 3.19
                                    Pin 5 (GND) = 0V
                                    Pin 6 (PWM 2) = 3.19
                                    Pin 8 (PWM 1) = 3.19
                                    Pin 11 (Vamp) = 12.74V
                                    Pin 12 (BLU) = 2.97
                                    Pin 14 (GND) = 0V
                                    Pin 15 (GND) = 0V
                                    Pin 16 (GND) = 0V
                                    Pin 17 (B5V) = 5.3V
                                    Pin 19 (B5V) = 5.3V
                                    Pin 20 (PS) = 3.16V
                                    • Akoen
                                      • Jun 2015
                                      • 28
                                      • Danmark
                                      In my previous post, the last reading are made by disconnecting the mainboard from the power board. In this scenario the backlight is turned on and the reading are higher than when the boards are connected.
                                        'Pin 12 (BLU) = 0' So the main board is not sending the Backlights ON signal. We can force on manually.
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • mrautom8
                                          Samsung TV UN75H6350AFXZC main board schematics?
                                          by mrautom8
                                          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                                          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                                          While relay is on, all voltage rails are present and steady (scoped) on main board.
                                          I love a good logic puzzle but getting lost without any schematics.
                                          No shorts on ANY capacitor main board.
                                          Thermal camera shows 3.3V inductor getting warm instantly but...
                                          10-19-2025, 06:32 PM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
