sammy PS60F5500, screen repairable ?
  • finntricky
    • Jan 2014
    • 449
    been offered this tv, has a single thin line down left side of screen, whats your thoughts, on this ?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: sammy PS60F5500, screen repairable ?
    That's usually unrepairable chip failure on the lower vertical VA COF. Since it's a plasma those things have an awful lot of voltage going through them and when you have a line on the screen its best just to leave matters alone or you'll make it worse.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      ^ Agreed lines out on any Plasma or Lcd are normally not fixable. Dont bother buying anything for it.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
