service menu RCA RLDED3955A
  • paulstef
    • Dec 2013
    • 724
    I replaced some LEDs from the backlight and would like to lower LED current. There is no adjustment in the regular menu. Anyone knows how to get into the service menu?
  • krygods
    • Dec 2014
    • 257
    Re: service menu RCA RLDED3955A
    There is no backlight option in the picture settings? I'm pretty sure this setting will achieve what you are looking for.
    • paulstef
      • Dec 2013
      • 724
      No, unfortunately nothing in the picture setting...
      • paulstef
        • Dec 2013
        • 724
        The circuit uses the OB3350. Look for several resistors in parallel which are in series with the cathodes of the LEDs (on the PCB). Increasing these resistor values will lower the current.
        The reference value in the OB3350 is 300mV, they used resistors of a total of 0.3Ohm so they were passing 1A (!) through the LEDs, I lowered it to 300mA and it still is bright enough.
          LCD LED TV Service Menu Codes
          TCL LED TV Service Menu Code
          LG LED TV Service Menu Code
          10-31-2024, 03:58 AM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • intercepter
          JVC LT-32CA120 service menu
          by intercepter
          I have JVC LT-32CA120
          Board:Vestel 17MB171
          I need rotate screen.It is possible in service menu and how to enter service menu?
          Thanks.
          12-10-2024, 10:29 AM
        • alltvrepairs
          Jvc Lt-65VU3000 reduce backlight from service menu
          by alltvrepairs
          I have just replaced led set of this vestel tv due to age.
          I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
          Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
          Thanks again....
          09-20-2025, 05:03 AM
        • sohail5307
          I need how to open this Dell service menu option in dell latitude e6420
          by sohail5307
          I need to open service menu of Dell laptops like image in attachment
          Ignore my English
          I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
          01-13-2023, 05:56 AM
