I have an LG LCD TV that has a backlight issue. The backlight will blink then turn off, and sometimes it will work for a while then go out. I found that removing the TCON from the main board, the tv would turn on and the backlight would stay on. Once it is reconnected, the backlight goes out again. Can a bad TCON board kill the backlight?
TCON Question
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by shelby5041hi
i have a samsung lcd tv
it powers on with sound and backlight but no picture
all voltages from PS are good 12v 3.3v and 5v
whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
no 12v at the tcon fuse
i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
the odds of having 2... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... - Loading...
