LG 60PA6500 image blanks after power on
    I have an LG 60PA6500 that quit. It's only 3 years old. Needless to say I won't be buying another LG.
    Anyway, it was last used watching broadcast television on channel 57-1 with sound off (I use optical to receiver for sound).
    When I power it on now, it powers up on 57-1, shows an image for 2-3 seconds, blanks for 2-3 seconds but still shows the 57-1 channel indicator, image comes back for 2-3 seconds, and then it permanently blanks but the channel indicator remains on. I have sound through the optical cable but all controls on the television and remote do not respond.
    The only way I can shut it off and turn it on is by yanking the plug. One time when plugging it in it actually stayed on, but the channel indicator remained on the screen and all controls were non-functional.
    I am an electrical engineer and have all the tools and goodies. I just need some direction here.
    Re: LG 60PA6500 image blanks after power on
    i am in now way an electronics tech but i have learned a lot from many of the guys on here
    first thing i would do is remove the back cover check for any visible defective components like bulging/leaking caps
    take clear and focused pictures of the board lay out and individual pics of the boards
    also there should be a sticker with voltage specs and you can do preliminary testing with a DMM
    someone with way more knowledge will comment soon and guide you in the right direction
      Here are pictures of the boards. I can find no visible problems.
      I'd appreciate some thoughts from someone with experience fixing plasmas.
        Do you have another input you can test the TV on for example HDMI or analog input?
        Or another channel?
          Service manuals:
          http://elektrotanya.com/?q=showresul...at2=schematics
            Or another channel?
            All controls are dead. I can't switch inputs.
              Originally posted by fzabkar View Post
              Thanks.
                OK, on the CTRL board you can see a pair of holes on the bottom right hand of the board marked EXT AUTO GEN.
                Turn the TV power off (unplug the set)
                Place a wire link between these holes
                Disconnect the LVDS cable between the main board and control board
                Plug the TV in...do the test patterns cycle continuously?
                  YES!
                  I saw a number of solid primary colored screens cycle by, and also some with black/white/grey patterns scrolling through.
                    You have a faulty main board.
                      Any recommendations on where to buy one at a reasonable price?
                        I would suggest shopjimmy but their stupid IP policy means any non-US addresses are blocked, so I can't tell you for sure.
                        Check using EAX number rather than EBR number.
                          So I hooked the main board back up to the CTRL board and the tv works fine now?
                            It's temporary. A problem going away on its own will come back just as easily. Probably a BGA soldering failure or failed flash memory
