ps-42q97hd no picture but have sound
  • comptek
    • Aug 2013
    • 606
    i have a PS-42Q97HD on first inspection i found a few bulged caps on the right hand side of the power supply, since i replaced them all seems well but still not getting a picture...
    I have checked all voltages and they all seem correct inc vs and va as per panel sticker, i checked y and x for and failed fets etc and all seem fine,
    the panel on switch is lighting up even the quick flicker when normally no signal etc would be shown but there is nothing at all, on the small logic board behind main logic the led to the right i believe its marked (2000) lights up and goes off and the led on the left near the y sustain ribbon flashes at 1 sec intervals
    Power supply is the BN44-00194A, all fets and transistors look and test fine been over all boards looking for dry joints as standard.
    No menu shows up or volume etc and i plugged another main board in from a PS-42Q96HD and made no differance i have all other boards from the 96HD but they are different parts even thoughthe screen is the same all but the screen im working has 42HD(W2+) on the barcode and the donor doesnt :/
    many thanks
    Gary
  • sordids999
    • May 2013
    • 2161
    Re: ps-42q97hd no picture but have sound
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • sordids999
      • May 2013
      • 2161
      How to test your buffer boards
      https://www.youtube.com/watch?v=51SZsfH60EY
      i think this is the Q97 pictures
      on the panel you will see a sticker this needs to see if all voltages are matching up VS/VA/VE/VSC
      etc etc
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Does the panel glow in a dark room ? Also common issue on these is the Ybuffer failing.
        • comptek
          • Aug 2013
          • 606
          yes Reece like i said the screen lights up and you get the flicker as it would show no signal etc comes on like a lit black screen
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            So either the control or Mainboard isnt running. Do you know how to do test patterns on these ?
            Also you could try entering the service mode do you know how to do that ?
            • comptek
              • Aug 2013
              • 606
              etc etc
              thanks Sordids 999 here is the info pics required
              On boards the voltages are as follows
              VS=206.7
              VA=63.8
              VSC=191.1
              VE=99.6
              • comptek
                • Aug 2013
                • 606
                yes tried the test pattern setting main board unplugged linked ps/on to ground and joined top to pins on the 4 way pin block at the top of the logic board pins 3+4
                no image
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Hmm sounds like the control board then buddy as the sustain drivers are working and you are getting panel glow however they arnt being told what to do. You did unhook the Lvds as well lol ?
                  • sordids999
                    • May 2013
                    • 2161
                    just unplug top connector then using a wire connect across pin 3/4
                    Did you test your buffers ?
                    • comptek
                      • Aug 2013
                      • 606
                      sorry couldnt load photos the proper way
                      [/URL][/IMG]
                      • comptek
                        • Aug 2013
                        • 606
                        that what i did with the logic board gonna check buffers now for shorts
                        • comptek
                          • Aug 2013
                          • 606
                          yes all that was attched to logic was he small cable going to psu and the ribbon cables going to boards
                          • sordids999
                            • May 2013
                            • 2161
                            no image
                            linked ps/on to ground ??
                            • comptek
                              • Aug 2013
                              • 606
                              yes well return as it shows on samsung site to take ps on low it power on the psu ok
                              • sordids999
                                • May 2013
                                • 2161
                                Just try disconnecting the cable going to the main board in the picture and connect wire to 3/4 on the control board for test patterns
                                • comptek
                                  • Aug 2013
                                  • 606
                                  Just try disconnecting the cable going to the main board in the picture and connect wire to 3/4 on the control board for test patterns[/QUOTE]
                                  thats what i did the only things connected was the small grey plug to psu and the ribbon cables
                                  lvds and mainboard unpluged mainboard end that is
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    And you have tested your buffer board ? and that voltage readings you took is that with YSUS/ZSUS etc connected ?
                                    • comptek
                                      • Aug 2013
                                      • 606
                                      yes i used pin 1 of the top buffer connector and on diode mode tehy were all around 0.620
                                      VS=206.7
                                      VA=63.8
                                      VSC=191.1
                                      VE=99.6
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        And the led on the control board is blinking ?
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
