Vertical lines, kdl-40lx900, i susect tcon
  • Dogcatdog
    • Sep 2015
    • 76
    Re: Vertical lines, kdl-40lx900, i susect tcon
    just tried that, with a hairdryer, held it about 5 mins around there it was a bit hot like almost to hot to touch with the backside of my index finger but not that hot.
    i hope that was hot enough.
    there was no change what so ever
    thank you in advance
    Originally posted by freakaftr8
    Ok apply some heat to ic303 and ic300 then test.
    • Dogcatdog
      • Sep 2015
      • 76
      what else can i test?
      • budwich
        • Jul 2015
        • 3097
        Originally posted by mistertv
        have you checked the flat heat-sealed under the metal frame of the display?
        OP, I don't think you ever responded to this suggestion. It might be worth you time to look. Something might be touching somewhere it shouldn't.
        • Dogcatdog
          • Sep 2015
          • 76
          somehow i missed that, well i took it completely apart to the bondings and to check if the bonds are the problem, that took ages, but they are fine and dont have a problem at all, touching them applying pressure did not change anything at all in the picture. so i guess the problem is the t-con,or maybe the mainboard? i dont know how to make sure, the question remains what could be dead there and how to test it, i would like to fix it on the component level.
          thank you very much in advance
          • Dogcatdog
            • Sep 2015
            • 76
            any other ideas?
            • Dogcatdog
              • Sep 2015
              • 76
              there is a chip marked MAX17079 http://pdf1.alldatasheet.com/datashe...17079_10.html_ on the tcon, is that the gamma chip?
              • Dogcatdog
                • Sep 2015
                • 76
                here are the Volt measurements i got for MAX17079
                Pin 01. - 1.70V
                Pin 02. - 0.00V
                Pin 03. - 1.70V
                Pin 04. - 0.00V
                Pin 05. - 1.70V
                Pin 06. - 0.00V
                Pin 07. - 1.70V
                Pin 08. - 0.00V
                Pin 09. - 1.70V
                Pin 10. - 0.00V
                Pin 11. - 1.70V
                Pin 12. to Pin 15 - 0.00V
                Pin 16. - 5.94V
                Pin 17. - 4.81V
                Pin 18. to Pin 32 - 6.08V
                Pin 33. - 0.00V
                Pin 34. - 8.12V
                Pin 35. - 7.39V
                Pin 36. - 15.35V
                Pin 37. - 0.00V
                Pin 38. - 3.41V
                Pin 39. - 3.26V
                Pin 40. - 0.00V
                • Dogcatdog
                  • Sep 2015
                  • 76
                  hrmm seems like this is the Gamma chip, i could not find the datasheet, its MAX9697A https://www.maximintegrated.com/en/p...l/MAX9697.html i attached a picture with the measured voltages, since i dont know which is pin 1.
                  so this is the best i came up with.
                  • Dogcatdog
                    • Sep 2015
                    • 76
                    i wonder what the other chip then is the MAX17079, i mean its function
                    • Dogcatdog
                      • Sep 2015
                      • 76
                      i found something.
                      there is an smd part marked, 33300 K028F,
                      When i try to measure the Voltage the pattern changes and or the screen goes black but im not sure if that thing
                      is the reason. it happens also when i push with my finger in that area, but only while i touch ground (chassis)
                      but same happens when i try to measure "capacitors/resistors"? around there
                      not sure what they are, cause there are no markings i will point them out in the picture
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        You're pushing a small signal current into those test points changing the pattern on the screen from obviously varying the voltage to the main Sony processor. I would be under the assumption that either the main processor which is that big Sony CXD9982GG either has a bad BGA connection to the board or its bad itself. I would try to heat it up and see if the pattern changes at all.
                        And yes that Maxim chip is the gamma processor. Sharp likes to use those for their panels
                        • Dogcatdog
                          • Sep 2015
                          • 76
                          so... shove it in the oven for like 5 mins at ca. 200 Celsius? or higher and or longer?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            well if you put enough time into it and you've got nothing left for it when I say go for it 450 degrees Fahrenheit for exactly 8 minutes. Then open the oven door turn the oven off let it cool for another 15 minutes before you touch it. And of course prop it up on something so the bottom of the board is not touching any metal surfaces
                            • Dogcatdog
                              • Sep 2015
                              • 76
                              well i can set the oven for 230 Celsius which is 446 Fahrenheit will that do?
                              i can just set the temperature in 10C increments on my oven, so either 220C, 230C or if 230C is not enough then 240C which is then 464 Fahrenheit, and i can set the time for exact 8 mins. on my oven, more or less concerning question: there are some components on the bottom side, so i wonder wont those just fall off the board when i try to reflow the solder? or will the surface tension keeps those on the board?
                              • Dogcatdog
                                • Sep 2015
                                • 76
                                ah one more thing, i can preheat the oven to the specific temperature, the question is should i shove the board in once the target temperature is reached,? or put it in from the beginning when i turn on the oven and let it get to 230C or 240C and then once it reached that, let it run for 8 mins, im asking because it takes a good 10 mins to reach the 230C i mean to preheat the oven. that would then mean the board is in for around 18 mins. so im not sure thats to long or not.
                                • jeffecor
                                  • Sep 2014
                                  • 78
                                  • kent
                                  #36
                                  No heat the oven up first! Then 8 mins
                                  • Dogcatdog
                                    • Sep 2015
                                    • 76
                                    so... shoved it in the oven for 8 mins. the tcon board, and thought well lets see, and well no change at all, then i thought, well lets try the mainboard, and hrmm still same no change at all in any kind, the symptoms are exactly the same, so i wonder, can it be caused by the power supply??? i cant imagine but who knows? what do you guys say? and if it is the SMPS what part of it could it be? what to test and what to test for?
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      You should try and trace the tracks going to and from the component in question. That might provide some clues (ie. are they going to grounds, power, interconnection to other ics, connection to resistors, etc?
                                      • Dogcatdog
                                        • Sep 2015
                                        • 76
                                        which component are we talking about? "33300 K028F?" ? im not even sure what it is, i know that 2 terminals lead to ground of that and 2 lead somewhere into the processor since its a BGA i cant check where
                                        • Dogcatdog
                                          • Sep 2015
                                          • 76
                                          btw. i am still not sure if the problem is from the tcon or on the mainboard, maybe somebody can help me to check the mainboard, somehow, there are schematics of the mainboard in the PDF from post #10 https://www.badcaps.net/forum/showpo...5&postcount=10 the actiual PDF> https://www.badcaps.net/forum/attach...8&d=1447079878 i dont really understand it and if it is even possible to test somehow
                                          • Stanley1843
                                            Screen Display Vertical Multicolor Lines
                                            by Stanley1843
                                            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                            06-29-2024, 11:54 AM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • Falki
                                            Colorful LCD Vertical Lines on Samsung ue55es8090
                                            by Falki
                                            Hello there, ive recently found an older 55inch Samsung SmartTV.
                                            Sadly it has vertical lines at the left and one line in the middle-right.
                                            I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                            I have factory resetted the TV as well but also with no luck.
                                            I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                            A similar issue has been posted as well but also with no actual response ...
                                            08-12-2025, 04:19 AM
                                          • gpo23
                                            Sony KDL-40V3000 - Vertical lines
                                            by gpo23
                                            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                            With the new t-con the color are good but there are vertical lines on all the screen :
                                            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                            Is there a way to fix the vertical lines on the new t-con ?
                                            Thank you for your help
                                            gpo23...
                                            10-04-2023, 09:11 AM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
