Samsung tcon board runtk5351tp
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    Hi i have had to replace several of the samsung tcon boards RUNTK5351TP does anyone know which ic is faulty on these and where i can buy from?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung tcon board runtk5351tp
    Well what faults do they display ? Also do you know how to use a DMM ?
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      They never display a picture, whats a DMM? sorry i still very new to this game.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        digital multi meter
        • andrews7523
          • Apr 2015
          • 117
          • lancashire
          ha ha sorry yes, but i don't know what I'm checking on a tcon as I've only ever used it to check a power supply
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            have you still got the set with a working tcon in/or a working tcon or is it just the faulty tcons you have
            • andrews7523
              • Apr 2015
              • 117
              • lancashire
              I dont i sold the set but i do have one working tcon and the faulty one as i buy as many working ones as possible as I've had to replace so many. Does it have to be in the Tv to check it?
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                not sure i was only asking as you could of done working voltage comparisons etc what is the fault you usually experience with a bad tcon in these sets
                • freakaftr8
                  • Oct 2012
                  • 3743
                  You should be able to connect an external 12 volt source to the tcon board positive of the voltage source to the fuse of the T con- negative on one of the ground lugs for the screw terminal it should be able to power up.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Do you know how to check for S/C if so you can check it with out a tv. S/C stands for short circuit.
                    • flocko
                      • Nov 2012
                      • 1121
                      • uk
                      The common fault with this Sharp board is a failed Micro KL5T3067 IC no money from China, but will need the right kit to remove and replace not an easy repair that is why they bring good money flocko
                      • andrews7523
                        • Apr 2015
                        • 117
                        • lancashire
                        oh thanks for your help advice everyone, Does anyone know of a decent website to order one of these chips Micro KL5T3067
                        • flocko
                          • Nov 2012
                          • 1121
                          • uk
                          Aliexpress
                          • Hakuu
                            by Hakuu
                            Hi There,
                            More Details
                            TV Model - LG OLED77G1PUA
                            07-12-2023, 02:37 PM
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • ohren
                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                            by ohren
                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                            The models launched in 2018 and 2019 respectively....
                            09-08-2023, 05:24 PM
