LG 37LC7D UK has image has no audio
    Re: LG 37LC7D UK has image has no audio
    Yep 2V is fine for an on signal. The 3.4V pin needs to measure around 3.4V.
    • bleed4me
      • Nov 2015
      • 122
      Ok tom66 I triple checked these numbers and here are the new values
      3.4on-2.49
      GND-0
      6.5-6.54
      A DIM-.02
      GND-0
      ST 5V BURST-5.29
      DIM-.16
      ERR INV-.85
      CTRL-3.25
      GND-0
      ST5V-5.29
      ON/OFF-3.03
      ACD-5.17
      GND-0
      12V-13.1
      GND-0
      3.4V-3.63
      GND-0
      6.5V-6.5
      now the remaining 4 pins I dont understand the board but here are the values
      0
      0
      .42
      .43
      • bleed4me
        • Nov 2015
        • 122
        Now riddle me this tom66 tried it again and check out these values
        3.4on-2.38
        GND-0
        6.5-6.17
        A DIM-1.6
        GND-0
        ST 5V BURST-5.05
        DIM-3.33
        ERR INV-.81
        CTRL-3.10
        GND-0
        ST5V-5.05
        ON/OFF-2.88
        ACD-4.93
        GND-0
        12V-12.71
        GND-0
        3.4V-3.48
        GND-0
        6.5V-6.16
        0
        0
        .45
        .45
        • bleed4me
          • Nov 2015
          • 122
          Values always change when I turn it off and bring it back up. One question I have is while the tv is off should any of these have a voltage value to them? Another thing is I mentioned a random video earlier I saw and wonder if this could be my problem.
          https://www.youtube.com/watch?v=b-bwX8_Ys70
            • 31188
            you really need a full recap.
            specially the small ones near the opto isolators.
            • bleed4me
              • Nov 2015
              • 122
              Appears a full recap is getting alot of votes so a full recap will be in the works. 2 questions though... This will sound rediculous but is that monster of a cap in the middle included in this recap and are those with what it appears to be some kind of shrink tubing are those caps as well and if so why are they covered like that?
                • 31188
                the high voltage ones can stay.
                the plastic cap is so you cant touch the can because they are rated at several hundred volts.
                • bleed4me
                  • Nov 2015
                  • 122
                  Just so we are on the same page the 4 small ones on the board with the shrink tubing are high voltage but get replaced?
                    • 31188
                    i'm refering to the 2 big ones in the center.
                    the small things your refering to are inductors if they are marked with "L"before the number on the board.
                    • bleed4me
                      • Nov 2015
                      • 122
                      OK perfect...I wondered what those were and now I know...thank you for sharing your insight! I will get the ball rolling on doing a full recap...
                      • bleed4me
                        • Nov 2015
                        • 122
                        OK riddle me this that last photo is a stock picture of my board on shopjimmy and has 2 monster caps on it...if you look at the pictures I posted earlier of my actual board there is only one monster cap...what's that about?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #32
                          The difference with two capacitors maybe one board is for 110 volts maybe the other board is for 240 volts im not 100% sure.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            please ignore you have already checked what i was going to say in post 1
                            • bleed4me
                              • Nov 2015
                              • 122
                              Just wanted to give an update on how the recap went... 18 caps total replaced and after an undisclosed amount of time has passed I know have a working tv WITH SOUND!!!! I just want to thank every single one of you for your knowledge and help. I could not have done it without you and it is much appreciated. You guys nailed it to a T...thank you so much. Im couldnt be happier that I found this forum.
