Element ELDFT406 " upside down picture"
  • iFixStuff
    • Oct 2015
    • 18
    Hello good folks, today I received EEPROM-ELDFT406-28H1403A V.1 from my favorite place, Shop Jimmy. The reason I purchased the item was because I had an issue where about ten seconds after you switch inputs the set would shut off. You were able to turn it back on if you want, but if you were in any input except tv it would shut back off. Using a $10 antenna on the set, I was able the run the set for 24 hours without it shutting off until I switched the input to HDMI.
    Ok, I installed the EEPROM and turned it on and my display was 180 out. I was curious if it would shut off if I switched inputs. I connected the cheap antenna and two DVD players and a chrome cast on the HDMI inputs. I just ran it for 4 hours cycling inputs and it never shut off.
    Now then, I'm aware of a service function that allows you to rotate the screen for diagnostics on my Panasonics, but I know next to nothing about this set and to make things worse, I don't have the original remote. I'm a fish out of the water and I have every reason to believe that the part is good and there is a way to correct my problem.
    Thank you all for your time.
  • numberonekiwi
    • Nov 2015
    • New Zealand
    Re: Element ELDFT406 " upside down picture"
    Hi have you looked here for service codes https://www.badcaps.net/forum/showthread.php?t=24809
    It sounds like it is a setting if that does not help try to find if you can program a universal remote for a service code for your TV
    I know LG TVs have 180 flip function for those that want to install the TV upside down
    • vinceroger69
      • Mar 2012
      • 6714
      maybe speak to shopjimmy they may of saw this fault before with eeproms they have sold.
      was the picture ok before you changed the eeprom?
      • iFixStuff
        • Oct 2015
        • 18
        I emailed shop jimmy again so I'm still waiting. I have a lg remote from another tv and it turns on the Element and I got into service mode but when I get there I can't go up or down in the menu. I have to use the volume button to control the up or down function when selecting inputs. So I try using the volume buttons on the remote while in service to go up or down and takes me out of service mode and adjusts the volume. I'm still searching for the correct remote or a good universal
        • garrymc123
          Luxor TV board input board change but picture upside down
          by garrymc123
          Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
          Is there anything I can do to flip the picture or do I need to change the board again..
          Garry...
          08-29-2022, 04:53 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • EazyBone
          Element E4AA70R black screen shows picture
          by EazyBone
          On this TV I got black screen with with picture.
          Tested the LEDs and they work.
          Had a hunch that this was similar to a ONN tv thread I found and wanted to post about this to possibly help someone else.
          The capacitor by the LEDs is bulging, 450v 10 uf. I suspect this is the cause. Will post results after replacing the capacitor. You could just replace power board as well I assume.
          https://www.badcaps.net/forum/showthread.php?t=110615
          Will post results when capacitor arrives...
          10-13-2023, 05:07 PM
        • kleito
          LC-52D85UN Software / Picture upside down
          by kleito
          Howdie
          I just replaced a TCon board on this TV, and now my Picture is upsidedown.
          I do not have a remote.Is there maybe another way to change this, like a software update?( which i can never find, probably due to the age of the unit)
          I cannot find a "flip"setting in the regular set up of the TV either
          Any help is appreciated.
          TIA
          12-01-2022, 04:39 PM
