TECH24HDLEDDVD Flashing Standby Light
  • sordids999
    • May 2013
    • 2158
    Bought this tv tonight but stuck in standby mode just standby light flashing all voltages tested good,so searched around for a main board but as usual nothing.But searched around on google for any firmware updates and found a upgrade_loader.pkg for vestel boards 17MB82S installed this onto the usb and kept pressing OK on the remote via the IR sensor and after a few attempts it alive
    Re: TECH24HDLEDDVD Flashing Standby Light
    Nice fix, care to share the file here? Or a link to it?
    • sordids999
      • May 2013
      • 2158
      http://www.vesteldriver.com/TV_ANASAYFA.html
      LED TV MB70 (CORE UPDATE)
      LED TV MB82 (V.0.6.6A CORE UPDATE)
      From here tom tv working fine now but i have noticed one thing the dvd drive does not work now maybe it was faulty when i bought it but thats another thing i need to work out
      • sordids999
        • May 2013
        • 2158
        Update::
        tv still working but it seems theres a fault still,Dvd player does not work and if you use scart lead the tv will not boot up unless its unplugged but hdmi seems fine maybe the LED TV MB82 (V.0.6.6A CORE UPDATE) is not right one for this tv
        • sordids999
          • May 2013
          • 2158
          Just testing voltages and all caps from the PSU are low and the voltages to the DVD player are only 3 volts
          does anyone have a idea why voltages on the power supply are so low ?
          thanks
          Power supply 17IPS61-3
          • 7ony
            Samsung plasma - flashing standby light
            by 7ony
            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
            No visible...
            08-31-2020, 05:18 PM
          • Bloopeta
            Samsung UE43KU6400U Flashing Red Standby Light
            by Bloopeta
            Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
            Power button does nothing
            Have unplugged the mainboard, and backlights illuminate.
            Have tried removing panel ribbon cables one at a time, and that makes no change.
            With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
            Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
            09-11-2023, 02:34 AM
          • fuxxy
            Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
            by fuxxy
            This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
            Plug the set in, and it will turn on and functions with no issues.
            After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
            Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
            08-02-2022, 09:44 AM
          • ChristianBr01
            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
            by ChristianBr01
            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
            04-23-2025, 01:48 AM
          • esqmooo
            HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
            by esqmooo
            Hello everyone.
            This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
            Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
            Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
            I tried long pressing on the power button, after several seconds it would go off then when the button is released...
            03-11-2025, 03:57 PM
