Sharp LC-70LE757U flickering display
  • bebeqq1231
    • Feb 2018
    • United state
    #61
    Re: Sharp LC-70LE757U flickering display
    Hello Everyone,
    New to the forum. I have issue with my sharp LC-70LE757U flicking 2 days ago. what's the first step i need to do? I already remove all the screw on the back and i have try to disconnect the t-con board and TV shout off automatically. I also try to hold the left side tab and it stop flicking but picture not not moving. Thank you for your help!
    • NoTV
      • Jun 2019
      Thanks so much for fixing my problem. I cut the driver tabs off the left side of my tv and it works now! There is a little black chip thing in the driver tab ribbon, two looked burned around the edges. Photo of burned vs good attached.
      • jbrillon4
        • Jun 2020
        • 3
        You guys here are great. A plethora of info. I have a 70 that has this issue. I'm gonna try the fix tonight or tomorrow and advise.
        • jbrillon4
          • Jun 2020
          • 3
          BOOM!!!! IT LIVES!!! Once again, thanks to all of you for the info to diagnose and repair my TV. I removed the tabs on the side I determined to be bad and it's perfect! Now my wife thinks I can repair electronics no problem. Uh oh. But the upside is it saved me $3000 and bought me some quality time!!!!
          Thanks again to all of you!
          • fjsingel
            • Jan 2024
            Ok, similar problem with a Sharp LC-52-64U. I have already replaced the TCON board and it makes no difference. The backlights seem to be working ok. Attached are some pictures with the left and right TCON connectors disconnected. The wavy lines are due to the cameral and are not real.
            1) With both TCON connectors connected, I get a fat horizontal line that start heavy on the left and is less pronounced on the right. Everything below the horizontal line flickers.
            2) If I disconnect the left TCON connector, the right side of the picture is good, just a little dark in the middle of the screen.
            3) If I disconnect the right TCON connector, the left side of the screen has the horizontal bar and everything below it flickers.
            Also, if you look closely, you can see a couple thin vertical lines on the far left and far right of the screen. Those don't bother me much while watching, probably a different problem.
            I would like to determine if I go after the tabs on this TV, or if the panel is just shot.
            Thanks for any advice.
            • Diah
              • Feb 2013
              • 6614
              for me the issue could be at main boarder not t-con or panel... best way put back yours org. t-con and do test t.cpn and panel as stand alone... them you will know if yours panel shot or not... read here we do write several time on how to run this stand alone test
              • fjsingel
                • Jan 2024
                Ok, thanks. I am trying the standalone test but I am missing something. I disconnected the 2 cables with the red x as shown in the picture. My guess is that I have to do some jumpering to get the power supply to run. Attached is a picture of the PS connector. Which signals do I need to jumper?
                Thanks!
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • moltensolderlabs
                  Sharp LC-52E77UN TCON activation WITHOUT motherboard. I2C reverse engineering help?
                  by moltensolderlabs
                  Hi everyone. [Sorry for the long, detailed post in advance].
                  I have a Sharp LC-52E77UN which randomly shuts down--could be within 15 minutes, could be 40 minutes, over 1 hour, it's unpredictable. From reading the service manual, I was able to get into service mode (where the K is displayed), and found the following error flag toggled: "04 Initial Communication Error 4 -- Error reason: To the communication setting reception," which, from contacting an eBay TV repair store, I was told is caused NOT by a bad TCON (which was my first guess), but rather the motherboard....
                  10-09-2020, 12:01 PM
                • x_orange90_x
                  TCL 50S535 bad tcon or panel issue?
                  by x_orange90_x
                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                  03-29-2025, 11:02 PM
                • vizi0n
                  Sharp LC-65N7004U / 65A6100M not powering on
                  by vizi0n
                  Hello Badcappers,
                  I have this tv that does not turn on. There are 2 model numbers on it : LC-65N7004U and 65A6100M.
                  When powering on the tv, the Sharp logo briefly appears with a dim S, and the tv turns off. While the Sharp logo is on the screen, the power light will blink 6 times (the last blink being very very quick).
                  I suspect a bad LED driver, or bad LED(s). Do you have any suggestion on how to troubleshoot this ? I have ordered a LED tester and should be getting it next week
                  Here is a link to a video showing what happens:
                  https:/...
                  01-06-2023, 01:22 PM
