Sharp LC-65N7004U / 65A6100M not powering on
  • vizi0n
    • Nov 2014
    • 28
    Hello Badcappers,
    I have this tv that does not turn on. There are 2 model numbers on it : LC-65N7004U and 65A6100M.
    When powering on the tv, the Sharp logo briefly appears with a dim S, and the tv turns off. While the Sharp logo is on the screen, the power light will blink 6 times (the last blink being very very quick).
    I suspect a bad LED driver, or bad LED(s). Do you have any suggestion on how to troubleshoot this ? I have ordered a LED tester and should be getting it next week
    Here is a link to a video showing what happens:
    https://youtube.com/shorts/hkBjgBdAios
    Thanks for your help !
  • nomoresonys
    • 12284
    • U.S.
    Re: Sharp LC-65N7004U / 65A6100M not powering on
    maybe try some resets first, be CAREFUL if you go into service menu, setting something wrong in there could brick/mess up your tv.
    • vizi0n
      • Nov 2014
      • 28
      I haven't found any service manual for this model, so I don't know how to load the service menu. The TV shuts off after like 5 seconds
      • nomoresonys
        • 12284
        • U.S.
        see if that helps: https://www.youtube.com/watch?v=ZAvXsglOIL4
        • nomoresonys
          • 12284
          • U.S.
          I believe on some sharps it's channel down and input that you need to hold while plugging in to get to service menu.
          • vizi0n
            • Nov 2014
            • 28
            Unfortunately there is no button on the TV itself, other than the power button. I've tried holding it a few seconds, or even holding while unplugged then plugging in, nothing seems to work. It feels like bad leds, but cant be overridden it seems.
            • alfatv
              • Sep 2020
              • 353
              Bad LEDs are typical on these
              • nomoresonys
                • 12284
                • U.S.
                I wolud do one more easy test before tearing it down to backlights, what do you have with just one ribbon cable attached from tcon to panel, do both sides, see if you get any display, careful not to let the pins of the disconnected ribbon cable touch the metal chassis or anything, make all cable connections and disconnections with tv unplugged from power.
                • vizi0n
                  • Nov 2014
                  • 28
                  hmmm I didn't try with half of the panel connected. I could try that later
                  • vizi0n
                    • Nov 2014
                    • 28
                    Well, just an update : there was one bad LED but I ended up replacing the whole set of loght strips and everything is now back to normal operation !
                    Thanks for your help and suggestions
                    • nomoresonys
                      • 12284
                      • U.S.
                      Nice work saving that 65 incher.
                      • Takayalee
                        • Mar 2023
                        Hi Vizion ,
                        I had the same model 65a6100m, the same issue sharp, red-light blink fast for 6 times, last 6th blink is fast , sharp logo appear for a second then shutdown.
                        How to fix this. Do I had to open its back cover?
                        Or what light stipe to order?
                        • vizi0n
                          • Nov 2014
                          • 28
                          Originally posted by Takayalee
                          Hi Vizion ,
                          Hi Takaya,
                          You need to take the tv apart completely
                          This includes (but might not be limited to, as i dont remember all the steps I did) : remove back cover, remove ribbons from tcon to panel, unclip the 4 boards at the bottom on the frame, remove the outer frame, remove the locking plastic strips around lcd, remove lcd, remove plastic diffusers, remove white background, remove strips and glue new ones in place reassemble in reverse order
                          I have ordered a set of these from this seller
                          https://www.aliexpress.com/item/1005...3eb51802kUmNfH
                          Quite cheap and worked ! It took about maybe 2-3h total. Ive glued the strips with silicone caulking.
                          Hope that helps !
                          • Takayalee
                            • Mar 2023
                            THanks so much, So happy that you reply so fast.
                            1. This video can use as a method to take every apart ??
                            https://www.youtube.com/watch?v=ZGR1tTlbPXw&t=205s
                            2. and when remove the glue strip. it's need hairdryer to heat it up? before remove it?
                            3. general white silicone caulking work? or it's need any specific one?
                            Thanks so much ViziOn
                            Originally posted by vizi0n
                            Hi Takaya,
                            Hope that helps !
                            • vizi0n
                              • Nov 2014
                              • 28
                              In the video the strips are screwed in, but on these tvs the strips are glued with some black stuff and some tape as well. You will understand when you get there
                              To remove the strip i’ve juste lifted one end of the strip and pulled. Since i was not reusing I just pulled hard.
                              Regarding silicone, its because that is what I had on hand. Just make sure that you make it as thin as possible so that the strip lays flat. Also wait for it to cure for a few hours before lifting the tv up, just so that the strips dont move/fall because not glued properly. I’ve used a regular household silicone caulking tube.
                              • Takayalee
                                • Mar 2023
                                Understood,
                                Already orderone from Ali, 2weeks waiting.
                                I will update when it arrived here.
                                Thank you
                                • everydaydealer
                                  • Jul 2020
                                  Understood,
                                  Thank you
                                  same issue. ordered the LED strips linked above. did it fix ?
                                  • Candis Usa
                                    • Jan 2025
                                    Just ordered from Aliexpress! I hope it fixes my tv
                                    • nomoresonys
                                      • 12284
                                      • U.S.
                                      So no updates from those "new members" it's customary to give an update after getting help, it's expected AND the least you can do.
                                      • Teban1306
                                        [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                        by Teban1306
                                        Hello everyone!
                                        I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                        System Information:
                                        • Model: Lenovo ThinkPad T14 Gen 1
                                        • Machine Type: 20S1S4E600 (Intel i7 variant)
                                        • Current BIOS: N2XET42W (1.33) - Latest version
                                        • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                        What I'm trying to achieve:
                                        Replace the default "LENOVO" boot logo with a custom image during POST.
                                        🔧 What I've tried:
                                        09-14-2025, 11:49 AM
                                      • Verlengsnoer
                                        Bios splash/logo change
                                        by Verlengsnoer
                                        at firs, i hope this is the right place to post my question.
                                        Im looking for a tool to change the bios logo.
                                        everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                                        i know that HP has a build in option to change the splash logo.
                                        but i want to change the manufacturer logo to an own logo.
                                        I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                                        10-28-2022, 09:52 AM
                                      • cloo
                                        Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                        by cloo
                                        I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                        It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                        So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                        After doing a factory reset this problem was gone and the picture was back to...
                                        01-06-2025, 06:02 AM
                                      • EazyBone
                                        Un50cu7000 2 blink oddity *partially solved
                                        by EazyBone
                                        I write this to maybe help another with this TV.
                                        So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                        The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                        03-18-2024, 10:24 PM
                                      • x_orange90_x
                                        Sony KD-60X690E 6 Blinks, no image
                                        by x_orange90_x
                                        I just got this today and it has the infamous 6 blink code. I've read it's quite possibly bad backlights, and I intend to check them soon. However, I was just curious if the Sony logo should it's shouldn't be appearing briefly between powering on and the light starts flashing. I've read at least one other person had the logo flash quickly, but mine does not show anything at all, not even a flicker. The green light comes on and after about 5 seconds the red light flashes. So I'd expect in this 5 seconds to see the logo. This leads me to believe it could be a power supply issue.
                                        I...
                                        12-10-2024, 09:10 PM
