oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    #41
    Re: oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....
    it was a hunch but i thught just maybe the power button board was bad and thats why i tried this experiment out of tv with remote....since i have time at work and no time at home lol
    • shelby5041
      • Feb 2009
      • 1505
      #42
      yes just confirmed it....power button board will not power on board outisde of tv....so i really think thats the issue.....the power button board is bad....??
      • shelby5041
        • Feb 2009
        • 1505
        #43
        i just tested the original board outside of tv that has a fried hdmi port the board will power on with remote control.only....so maybe that board will work just minus one hdmi port????.....i would figure the fried hdmi port would not allow to power on....but bottom line is at a minimum the push button power board is bad...when i get home i will test boards in tv and hopefully tv will actually power on.....would be nice .....the guy i bought tv from gave me the orig fried board and another board he bought...the one he bought is dead...i get no standby at all.....so thats why i bought another one...so i have 3 main boards.....and originally thought the one i bought was bad it did get standby but no power on....until the test i just did....so its possible the board is actually good..ill update....thanks for all help
        • shelby5041
          • Feb 2009
          • 1505
          #44
          and in the future if i get a standby light but tv wont power on at all....something as simple as testing with a remote can maybe rule out a bad power button board lol...ive never seen a power button board go bad ....and i have repaired over 50 lcd tvs
          • shelby5041
            • Feb 2009
            • 1505
            #45
            thanks bud m freak and reesey
            • freakaftr8
              • Oct 2012
              • 3743
              So it's working now?
              • shelby5041
                • Feb 2009
                • 1505
                #47
                dont know...at work
                • shelby5041
                  • Feb 2009
                  • 1505
                  #48
                  the power on light powers on out of tv via remote only
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #49
                    update....using remote .....tv does power on and backlight comes on but no picture...no osd...nothing
                    fyi... tv tcon is not removable.....so any ideas?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #50
                      is there a fuse on the tcon you can then check the voltage of to each side of it
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #51
                        yes..that was my next step but no time ...had to go to work....i work 7days 12.5 hrs day....
                        i hope fuse is blown....the hdmi oower surge from cable tv alresdy blew main board and owr button board....
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #52
                          what sucks is tcon is not replaceable on this tv.....cheap ass tv.......the lcd screen is def not turning on....the backlight coming through is coming through a powerless panel......
                          • shelby5041
                            • Feb 2009
                            • 1505
                            #53
                            hey vince is there a possibility that the fuse blew on tcon from the power surge that fried the hdmi port on the main board? or is that a 100% no....
                            i already proved the power button board got fried from the
                            im not at home to check just curious
                            thanks
                            • shelby5041
                              • Feb 2009
                              • 1505
                              #54
                              update..i get 12v at fuse on tcon........both sides. ....lcd panel not turning on...no pic no osd...nothing
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Try pulling one ribbon cable off the T CON to the panel on one side see if that side turns white then see if you have a picture on the other side try it this way and then swap cables and disconnect the other side
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #56
                                  hey freak tcon csbles non removable
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    Take the frame off and check each tab bond driver with you finger see if any are burning hot if they are failed.
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      #58
                                      hi reese......tcon board is non replaceable and non repairable .....so not sure the point in doing that...at this point tv seems done.......cheap ass design.....
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #59
                                        here is a pic of the unusual tcon board that appears to be not replaceable
                                        the ribbon cable is permanently connected to the tcon and possible to the panel
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #60
                                          now im confused....where does the ribbon cables attach if not directly to panel
                                          here is a photo of the board out of tv from some ebay seller ....item was sold
                                          but it appears it may be replaceable.....i would have thought the ribbons go from tcon directly to panel like most lcd tv i have seen
                                          i cant find this part anywhere online at all..........nowhere
                                          im hoping it may be replaceable and not diresctly mounted to the panel like i thought it was......usually the ribbon cables are directly mounted to panel and then hook up to the tcon via connectors....from what i have seen but this one the cables are mounted permananet on the tcon
                                          i still do not know if the board is def or the panel is.or bad connection to panel...i fo get 12v at the fuse on the tcon but panel will not power on
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
                                          • jasonbay13
                                            Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                            by jasonbay13
                                            picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                            am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                            12-01-2023, 09:55 PM
                                          • Nicktronic
                                            Samsung UN70NU6070F Standby Light flashes twice
                                            by Nicktronic
                                            Hey Everyone,
                                            So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                            I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                            03-27-2023, 07:01 PM
