LG42PT350R clicking and doesn't turn on
  • buchman
    • Aug 2015
    • 283
    • greece
    I checked all the capacitors on every board and they are fine.
    All diodes are fine too.
    Checked all the resistors and didn't find anything bad.
    The fuses are good.
    No picture and no sound.
    I have noticed that when the power board isn't connected to anything ecxept electricity, it shows the VA and VS as noted but, as I connect the YSUS, ZSUS, main board or the T-CON, the VA and VS drops to less than 1 volt on the power board.
    Is the VA and VS should always stay on their values?
    Thanks in advance,
    Edward.
  • wills123
    • Jan 2014
    • 72
    • england
    Re: LG42PT350R clicking and doesn't turn on
    You connect each one in turn and the voltages drop? Or all of them?, try to connect all but the x an y then see if the voltages still there, test for short circuit on x an y between vs and ground for a starter
    • buchman
      • Aug 2015
      • 283
      • greece
      If I connect only one of the above boards to the main board then the VS and VA drop. How do I
      • Hamie
        • Apr 2014
        • 1383
        Depending on the model, if an error is detected the mainboard will stop sending then vs-on signal.
        Alternatively it could be failing under load.
        You can solder in a 200w (or 2 x 100w in series) light bulbs between vs and ground. The bulb should stay lit, if it flickers or turns off you may have a problem with your power supply.
        What are the vsc, -vy and z-bias voltages.
        • buchman
          • Aug 2015
          • 283
          • greece
          If I disconnect the main board and, let's say, only the zsus or the ysus connected, then the vs and va also drop. I mean that even if the main board is disconnected, the vs and va drops if I connect anything beside the power supply board.
          Please guide me how do I check the VSC, VY and z-bias voltages?
          I have a digital multimiter and the understanding, just need some guidelines.
          Thnk you so much guys.
          • Hamie
            • Apr 2014
            • 1383
            If you disconnect the Main board the power supply is not going to turn on.
            The main board sends the signal to turn the power supply on and off.
            The power supply would need to be 'jumped on' if you disconnect the main board.
            Vsc, -vy test points are on the y-sustain. These are sometimes measured across a marked resistors.
            Z-bias is on the z-sus.
            • Hamie
              • Apr 2014
              • 1383
              Z-bias is measured across this resistor, put your probes to the corresponding + and -
              You don't have a clear picture of the y-sus so I can't see the other test points, but they will be similar to the z-bias.
              I recommend putting back in the screws so it's properly grounded.
              Remember that your vs and va are dropping so you'll need to quickly test these points before they drop off.
              • buchman
                • Aug 2015
                • 283
                • greece
                Tested for Vs and Va and it shows a few milivolts (put the probes on and then turned on the TV).
                Tested the Z-bias and Vy and they show a few milivolts too.
                Didn't find the Vsc test point.
                Didn't try to solder 200W light bulb.
                Bridged the EXT_AUTO_GEN (with main board disconnected) and didn't see any test patterns.
                P.S. I have no light (green or red) on the T-CON or the main board (I don't know if there should be at all)
                What should I do next?
                Thank you very much guys.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  i think if possible you need to check the psu voltages first im not sure how to force on this psu maybe hamie can advise.
                  • buchman
                    • Aug 2015
                    • 283
                    • greece
                    Hamie? Tom? Anybody can guide me what to test next?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Checked Vs on signal ?
                      • buchman
                        • Aug 2015
                        • 283
                        • greece
                        where do I check it?
                        • howardc64
                          by howardc64
                          Yesterday, 05:17 PM
                        • slimmy182
                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                          by slimmy182
                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                          Looking on google I found this:...
                          01-14-2023, 11:55 AM
                        • maxim2511
                          LG 55EC930V OLED - swich on swich of no screen
                          by maxim2511
                          My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                          Then I get an idea to take it apart and clean boards from dust.
                          In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                          Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                          05-14-2021, 02:21 AM
                        • brzostos
                          HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                          by brzostos
                          Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                          After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                          Original HP 150W power supply, the diode in the power socket lights...
                          10-01-2024, 01:34 AM
