Does this 47LS4600 have bad T-Con, driver boards or Main board?
  • Pioneerx01
    • Apr 2015
    • 241
    • US
    When I turn it on, only right half works just fine and left half is white (my first thoughts t-con issue).
    As I am taking the TV apart it becomes more and more apparent, someone was in here before as I see missing screws, wrong screws, stripped screws,... Then I get to T-Con and left ribbon cable was disconnected, with latch lifted. Could it be that simple, of course not.
    I plug the ribbon cable in, turn the TV on and besides back lights I get no image on either half. No menu, channels or volume indicators. I disconnect the left cable and I am back at beginning with right half working and left half white.
    So I plug the left cable in and disconnect the right one, but still no image just back lights. I have also swapped the ribbon cables, to confirm they are both functioning and they are.
    So I have gotten another T-Con board, but I am still having same issues. At this point I am thinking bad driver board. Would I be correct, or could it be somehow main board related?
  • Hamie
    • Apr 2014
    • 1383
    Re: Does this 47LS4600 have bad T-Con, driver boards or Main board?
    bad panel im afraid
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Bad Panel IMHO sorry. A failed Tcon or Mobo wont cause a line to go out on the screen.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        check out the tcon with an oscilloscope. then you know if both sides are actually working or not.
        • advant
          by advant
          02-03-2020, 12:25 AM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
