17MB35-4 3.3V Shorted Help ?
  • wills123
    • Jan 2014
    • 72
    • england
    Re: 17MB35-4 3.3V Shorted Help ?
    Nice one hope you get it replaced easy enough
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by stj
      does it have a pad under it?
      No its just pin soldered which I can easily replace, I have a chip on order will make a youtube video on how it goes.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Cheers pal, hopefully its just that chip
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Picture of faulty Hdmi chip removed.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            The new Ic has arrived to day going to get on with installing it Must say for coming from where ever in China this arrived fast and was well packaged. Welldone who ever sold me this
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Theres more to be done on this, I have replaced the Hdmi Ic successfully however the regulator U121 still has a short across the adjust and output pins. The Hdmi Ic now doesn't burn my finger however the regulator does and its not the regulator at fault. Any more suggestions ? Made it this far not ready to give up !
                A short between adjust and output can be ok if the regulator is configured for 1.2V output. (That is how you get an adjustable regulator with 1.2V reference to output 1.2V)
                BTW, nice work removing that IC! Bloody clean pads... How'd you do it? It took me years to get to the level of cleanly removing TQFPs etc.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  #28
                  Cheers mate here a pic of the Ic soldered:
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    I did the following to go about replacing the Ic:
                    Apply Flux (gel type) around all pins of the Ic.
                    Use hot air at 400d and heat ic until flux is bubbling.
                    Focused heat on one side of the Ic.
                    When solder is melted on that side, use a small pair of tweezers and pry it up.
                    Apply heat to rest of Ic until it lifts.
                    When Ic is removed use solder wick and clean all pads down.
                    Use Ipa and clean all pads off.
                    I did the following when replacing the Ic:
                    Position new Ic perfectly.
                    Apply small amount of flux to each opposite corner
                    While holding Ic in place get some solder on iron and tac corners that are fluxed.
                    Check alignment of Ic again.
                    Flux all pins of Ic.
                    Flood all pins with solder.
                    Apply more flux and wick solder off with iron.
                    If there are shorted pins wick solder off with solder wick.
                    Clean with ipa.
                    Check with microscope.
                    When im finished doing this I will upload the repair log, I have recorded how I have done everything.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #30
                      This should be a 1,8v output, how ever the output reaches 0.4v and when its in circuit it drags the 3.3v down to 3v then the tv shuts down, also it gets very hot. Something on the output side of that is shorted but its not the Hdmi chip its something else but what ? This is one hell of a crap shoot haha.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Anyone, I cant find out why the 1.8v section is shorted ??
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #32
                          Found by using a spare Mainboard that the 1.8v from that regulator drives the hdmi chip and its respective drivers so something in that section is still short.
                            Could be one of the ESD protection networks or the EDID EEPROMs.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #34
                              Hmm the ESD is all good for the Hdmi processing area took off all the diodes and caps. Where are the EDID Epproms on these boards ?
                                Will be adjacent to the HDMI ports in most cases.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  Ok will have a check cheers Tom.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #37
                                    Not those Epproms going to put this aside for a few days as im about to throw the whole lot out the window lol, will let you know if I find anything else.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      Well some sad news, I fixed the board it was bad soldering on my part. I have improperly soldered a very small MLCC which I had shorted its pads to ground and its part of the 1.8v section, seems good doesn't it ?
                                      Well, after powering the tv on I soon discovered that the Lcd glass is cracked, there are several spider web type cracks on the glass causing no image what so ever. This would have been done by the owner. So a whole bunch of crap shooting later and its trash anyway.
                                      Thanks for the input chaps at least now I can make break even and make a bit of profit by selling the boards on ebay. This was a cluster fuck but ohh well
                                        Could you see the cracks with the power off? I always check TVs with a light, and I can see cracks easily.
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #40
                                          I never checked Tom tbh and no its not an easily visable crack. Ohh well got 5 more other 32" to fix so will get on with them.
                                          • npielawski
                                            MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                            by npielawski
                                            I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                            I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                            10-15-2025, 01:53 AM
                                          • mr.Data
                                            Shorted inductor means short circuit? Asus ROG Gaming laptop.
                                            by mr.Data
                                            I have a dead Asus ROG gaming laptop with liquid damage. When I measure the first mosfet, there is 19V. On the second mosfet there is nothing on the input and 4.3V on the output but it is not continuously. It is going up and down.
                                            I have read this article:
                                            https://www.prospace20.com/2022/03/h...ad-laptop.html
                                            Is it through that inductors can never be shorted?
                                            I have 2 inductors near the GPU that are shorted. Does this mean that the GPU itself is shorted? How can I know for sure?
                                            11-15-2022, 04:31 AM
                                          • privato89
                                            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                            by privato89
                                            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                            Let's begin:
                                            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                            03-26-2024, 06:37 AM
                                          • Yanleb
                                            Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                            by Yanleb
                                            Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                            I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                            D608, good
                                            D618 RF101L4S, good (See warning 1 below)
                                            D619 RF101L4S, good (See warning 1 below)
                                            D865 RF101L4S, shorted (See warning 1 below)
                                            IC464 Inverter HA MC74HC1G14, shorted...
                                            03-09-2020, 12:00 AM
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
