Re: Led back light
I've just ordered the maplins ones. Will update once fitted
Led back light
Re: Led back light
Would it be easier to find another strip and graft the working LEDs togetherLeave a comment:
Re: Led back light
"The maplins are 350 that OK?' yes, you are going to be running at the lower current, but I do not know if it will have color shift at lower current drive or not. The existing strip is probably using the copper pads for heatsink, so if this LED should be able to handle it, we still do not know what your LED strip look like, the original probably does not have good thermal management either so they burn out.Last edited by budm; 10-14-2015, 02:27 PM.Leave a comment:
Re: Led back light
http://www.maplin.co.uk/p/white-led-n67jq
These?
My board has 5 LEDs and says vf max 18v so I assume each led is 3.8v Ish?
Says if= 320ma the above is if 350ma. That ok?
So you will be running at lower current which will be fine, I also doubt that they are running them at MAX If.Leave a comment:
Re: Led back light
These?
Says if= 320ma the above is if 350ma. That ok?Leave a comment:
Re: Led back light
What does the one in the panel look like?Last edited by budm; 10-14-2015, 02:09 PM.Leave a comment:
Re: Led back light
The meter didn't power them had to use a battery. Have 6 LEDs out. 8 strips of 5 led and 3 on 2 strips gone. I've removed the bad ones... Any idea where a can get replacements?
Spell check -- traitor = resistorLeave a comment:
Re: Led back light
It wont be too noticeable the brightness difference and what do you mean by traitor ?Leave a comment:
Re: Led back light
Ok I will check them all and when I find the bad one I just solder the traitor in its place and it should resume normal function? Minus some brightness of courseLeave a comment:
Re: Led back light
i test led's with an old coincell from a motherboard - i have lot's of used ones.Leave a comment:
Re: Led back light
The meter will have enough juice to dimly illuminate the leds.Leave a comment:
Re: Led back light
You should put the current limiter resistor in series with the power source when you try to test the LED.
http://led.linear1.org/why-do-i-need...r-with-an-led/
https://www.sparkfun.com/tutorials/219Last edited by budm; 10-14-2015, 10:00 AM.Leave a comment:
Re: Led back light
That's what I was referring to... What if the meter doesn't output enough voltage to illuminate it. So 3v should be ok?
Bush bmk40Leave a comment:
Re: Led back light
Be aware that multimeters vary greatly in the output voltage when in diode mode. For example, the Fluke 87V will output more than 7V in diode mode. I have a Brymen meter that only outputs 1.5V in diode mode.Leave a comment:
Re: Led back light
LEDs will be open, short or working, if its short your meter will show this, if it is open it will show that also, and if it glows its working. You fail to tell use the make and model number of the set you are trying to fix? not all LEDs are the same voltage ?Leave a comment:
Re: Led back light
then the LED is duff..a 3v supply to each individual diode should provide illumination.
Often,the led itself is visually burnt.
Good luck!Leave a comment:
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by jinu_jHi
4. D930 - Shorted Schottkey Diode...-
by jdawg99Hi All,
I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the... - Loading...
