i found thistvin dumpster watched a video on youtube and ended up buying a tcon board from a "broken screen working" tv needless to say this did not fix my problem and i found this forum i am very capable if i know what i am doing however i dont know much about component repair although i think if pointed in right direction i could handle it what i cannot find is a listing of what components should have what power i cannot see any burnt resistors or any bubbled capacitors the tv will hook up via hdmi and have audio which was what led me to believe it was tcon card which the "new to me" one i am not 100% is good or bad any help would be greatly apreciated
Vizio Vo370m display lights light comes on no display
Tags: None -
Re: Vizio Vo370m display lights light comes on no display
the back lights are workingi have whole tv apart well boards still on it and have been testing a few places for power that ican tell what it is all the fuses test good (what ican tell are fuses and i have tested a few of the voltage regulators on the main board although i do not know what the volts should be they all seem to functioning ( i have a high and a low ) iam wondering if there is a list of components and the values they are supose to be so i could go through the boards themselvesLast edited by h82loseejr; 10-10-2015, 12:22 AM.Comment
for the voltages if they aren't printed on the board you will need a service manual, for the regulators they will be either fixed or variable you would have to run the part number if they aren't marked. resistors marked by the color band or either a number on smd, caps are all marked. what exactly is it not doing?Comment
well plug in and visio glows orange hit power and it truns white 3 seconds later screen apears to turn on (backlights come on) it glows as it should i assume and it has no video i can hook hdmi up and fish through the inputs althogh i dont remember if it was hitting input button or using channel up and down anyway i had sound coming out of it but no video at allComment
either the main board or the display itself. mainboard is fixable display isn't. I would guess the eprom is bad, vizios are well noted for eprom failures. budm is the resident expert on these and he will chime in I am sure. I mostly do plasma the lcd led sets once and a while. shop jimmy usually has the eproms in stock.Comment
i never noticed before it seems to get pretty warm the screen itself i always had led so ihad it laying face down and testing voltages and such i hope i didnt screw itup more well really it dont matter i guess i found it and only have the 20 in the tcon and may be able to return itComment
also here is the service manual, you might try freezing the eprom with a can of compressd air turned upside down and see if anything changesComment
Do get 12VDC at the SMD fuse on the T-CON board? Use chassis as the GND ref for the meter.Never stop learning
budm from whaat i can tell there is only one fuse on tcon and below it it says
f1 125v/2.0a i checked fuse it is not open will that be 125ac? or dc
i checked the fuse and there is no power ac or dc at the fuseLast edited by h82loseejr; 10-10-2015, 12:57 PM.Comment
either the 12v power supply or something on the main board budm should be around somewhere. he is the expert on these. are any of the power board connectors marked with voltage if so look for one that says 12 v and see if there is any voltage there.Comment
there is and there is 12v at the connectror coming off power supply boardComment
check on the mainboard to see if there are any fuses some times there on the front of the board some times the back we need to find why the 12v isnt getting to the tcon.Comment
f1 and f2 show on the shop jimmy pic on the mainboard these are surface mount fuses little larger than a resistor with gold ends. several 0 ohm resistors on the backside which may act as fusesComment
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
This specification for the Acer Chromebook Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) boardview and Acer Chromebook 311 CB311-11H - (MediaTek MT8183, 4GB, 64GB eMMC, 11.6 inch HD Display, Google Chrome OS, Silver) schematic. Our users have donated...09-07-2024, 01:00 AM
- Loading...
